I am calling for any help, I have a Transit 2014 L3H3 2.2 125hp, the van had an engine change at 98,000 under warranty at Ford in Hemel Hempsted 16 months ago, since the engine change I took the van back twice for a diesel knock that I was not happy about and kept getting told they couldn’t find anything wrong, 2 weeks ago the van went in to Limp Mode so I gave the van back to ford, to which they have now informed me that the van needs a new engine AGAIN!! Due to injector failure, seeing as they never replaced the injectors with the previous engine the first time around it was down to me, I find this very hard to swallow having seen now that these vans have this as a not so uncommon problem. Did ford not recall this issue? Has anyone else had a problem similar to this and what did they do? Ford want to replace the engine and injectors for the sum of £8,000 the new engine has only covered 16,500 miles. I am stuck between a rock and a hard place and just wondered if I’m alone
Stephen
