Wanted Webber pinto 34ICH carb for 1987 transit120
Postby Eaglegirl » Sun Mar 10, 2019 11:54 am
Hi everyone asking for help , looking for a carb Webber pinto 34ICH for our 87 Ford transit 120 autosleeper ! Can anyone help please ? Been quoted over£200 any recons about ? Thanks
Eaglegirl
Re: Wanted Webber pinto 34ICH carb for 1987 transit120
Postby vanfox » Sun Mar 10, 2019 3:10 pm
I had a pinto for a long time, tried various carbs, dellorto, weber etc, came back to the VV. Properly set up these are as good as any third party and you get the hot air connection from the air filter to avoid carb icing.
Mine came from a pile in a breakers, guess I was lucky.
vanfox
Postby jonochap » Sun Mar 10, 2019 10:12 pm
I think I may have one still, will have a looksee tomorrow. Muttley may have it though , I’m back on a vv now though and much better.
jonochap
Postby RustWidow » Sun Mar 10, 2019 10:28 pm
My mk2 pinto ran best on a vv too...weird huh? Lol
RustWidow
Postby Eaglegirl » Mon Mar 11, 2019 12:55 pm
jonnochap thanks if you do have one id be over the moon, obviously id pay postage or whatever you want for it . Thanks again
Eaglegirl
Postby Kjeles » Mon Mar 11, 2019 9:44 pm
[... ran best on a vv...]
What were the signs that the Weber 34 ICH performed worse – or less well – compared to the original VV?
I was recommended by a car mechanic in Liverpool to replace my VV with a Weber 34 ICH. So I bought a new Weber a year ago, but have not replaced the old VV yet.
I have a Weber 32/36 DGV sitting on a Pinto in another Transit 87 camper. The van seems to run fine. I like the manual choke.
Kjeles
Postby RustWidow » Mon Mar 11, 2019 11:20 pm
Kjeles wrote:[... ran best on a vv...]
I had a Weber conversion on my mk2 2.0 litre pinto, it wouldn’t idle properly and fuel was just sucked up, mpg was rubbish. We fitted a vv and the engine ran sweetly with no issues, the Weber was forever getting something stuck in the needle valve and I broke down every 10 minutes, or so it seemed, muttley would clear the jet and 10 minutes down the road it would get blocked again. We had an extra in line fuel filter too! So, yes, my van ran better with a vv. does that clarify things for you? :)
RustWidow
Postby Kjeles » Tue Mar 12, 2019 7:12 am
Thanks for the details. Interesting.
I'm wondering if fuel pressue might have been an issue? I read somewhere that Webers are sensitive to high pressure. Hence, I mounted a fuel pressure regulator with my Weber 32/36 DGV and also bought one to be mounted with the Weber 34 ICH (if I ever get around to it).
Kjeles
Postby jonochap » Tue Mar 12, 2019 6:24 pm
Sorry Kj, it may still be with muttley, no doubt RW will ask him if he knows where it is if you’re running a standard fuel pump then the pressure won’t be too high for any of them, if it’s electric you may get issues
jonochap
Postby Kjeles » Thu Jun 13, 2019 5:24 pm
Indeed, I have the original, mechnical fuel pump on both vehicles. The pressure reads 3.8 psi at 3000 rpm and increasing to 4.0 psi during quick drops in rpm. The Weber carbs ask for max. 3.5 psi and preferably 2.5 psi. Maybe not a big problem, but I have installed regulators on both anyhow, giving the prescribed, constant 2.5 psi.
Someone recommended adding gaskets under the fuel pump instead of installing a regulator. I tested the effects of thicker gaskets:
1. Standard gasket 0.8 mm thick: Pressure 3.8–4.0 psi
2. Standard gasket 0.8 mm + one additional 0.7 mm gasket, 1.5 mm total: Pressure 3.7–3.9 psi
3. Standard gasket 0.8 mm + two additional 0.7 mm gaskets, 2.2 mm total: Pressure 3.6–3.8 psi
4. Standard gasket 0.8 mm + three additional 0.7 mm gaskets, 2.9 mm total: Pressure 3.5–3.7 psi
The additional gaskets didn't bring the pressure down to the desirable 2.5 psi. On the other hand, maybe 3.5–3.7 psi is good enough.
I have finally installed the Weber 34 ICH on the second vehicle. It runs like a charm. No more excessive fuel consumption. No more dieseling after ignition turn-off.
Kjeles
Postby ABA » Thu Jun 13, 2019 5:41 pm
i had a mk 3 run it with a webber carb for over 15 years run fine the original carb original carb was a heap if crap
ABA
