If I press a button on this light
It works this one..
Altransit wrote:You can't use standard LED bulbs in the front cab lights, as the polarity is wrong. The only way is to solder-in a small LED board, which is what I've done.
davyjcb wrote:There are no switches in the roof.have you got all the plugs correctly orientated ? You can't go wrong with the front unit as its the light unit for the alarm system and the spades are at 90* to each other,also I'm wondering if they are switched through the bcm cos I have had a few vans that haven't been fitted with the trailer tow module and have overloaded the lights - and they would not work until the van was plugged in and the fault cleared by ids / forscan
Users browsing this forum: DanMK7uk, Majestic-12 [Bot]
