Need some advice lads
have just bought the above van and it failed the mot on a few things (have done most of the jobs)
but the one fail was n/s/r wheel bearing has excessive play and I cant find any play so am I checking it wrong
now as many of you know im quite good on the tools
the only movement I can find is when you have it on stands you can pull the wheel outwards slightly but its the same the other side
is that normal
so how do I check play in the rear bearings and if it has gone il send it in to be done
regards craig
