cutting out
cutting out
Postby escort » Mon Nov 21, 2005 9:45 pm
hi
can anyone help
ive a h reg 2l tranny thats got a intermitant fault
its cuts out when i stop at junctions etc but if i catch it right it ticks over feal rough [ like its firing on 3 cylinders ]
its starts again first time and is ok again untill the next timt wich culd be 1 mile could be 10 miles
hers the best ive change the carb the disributor the plugs the leads the petrol pump the coil
please help im pulling my hair out
cheers george
george
escort
Postby MrMPuk » Mon Nov 21, 2005 10:16 pm
Guess that's a pinto, would say have a clean of the carb.
cutting out
Postby escort » Mon Nov 21, 2005 10:38 pm
thanks mate but ive changed the carb
george
escort
Postby pike » Mon Nov 21, 2005 10:57 pm
hi mate i had same prob come 2 a juction and it would die mine wos the pipe that feeds the survo on the brakes it had a split in it so when u pump the brakes lost air and died poss thought
pike
Postby MrMPuk » Mon Nov 21, 2005 11:00 pm
Did you clean the carb before you fitted it?
Postby madmark » Tue Nov 22, 2005 5:52 am
has it got the valve in the side of the carb with a wire on it?????? :?
cutting out
Postby escort » Tue Nov 22, 2005 4:31 pm
hi
ive checked servo pipe thats ok
ive cleaned the carb
ive checked the feul cut of soliniod on the side of the carb
cheers george
george
escort
Postby rover » Tue Nov 22, 2005 5:40 pm
Which carb is it? Webber or VV?
If its the webber its unusual..
If the VV then its probably the choke sticking, mine used to do it every now and then, I would just jump out and give the choke unit a tap with the handle of a srewdriver.........eventually I took the choke out altogether and have been running without one for two years, I keep meaning to get round to getting a twin Webber and manifold....one day!
rover
cutting out
Postby escort » Tue Nov 22, 2005 7:07 pm
hi
its a webber and ive changed the carb still the same
cheers george
george
escort
Postby rover » Tue Nov 22, 2005 7:32 pm
The best way to tell if its the carb is to hold the choke open manually and see if it ticks over any better then.
If not then have you changed the dizzy cap n rotor? is the ingintion module playing up? has the coil got any visible damage?
rover
cutting out
Postby escort » Tue Nov 22, 2005 8:34 pm
hi
the chocke flap is open
checked or changeddizzy cap rotor arm
havent changed the petrol filter but have checked petrol in the carb
cheers george
george
escort
Postby bortaf » Tue Nov 22, 2005 10:56 pm
Check the connection on the dist and ignition modual on the inner wing for rust or water it may be the modual on the way out but i dout it.
Does the servo hold it's vacume when the engine is off? could be a split diaphram inside the servo.
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby Smooth Hound » Wed Nov 23, 2005 6:51 pm
If you increase the idle speed it would probably maintain enough revs to keep it going - doesn't get to the root of the problem but can cure it.
Mike
Smooth Hound
cutting out
Postby escort » Fri Dec 09, 2005 8:20 pm
re the cutting out problem
still there but not so frequent
does anyone know how the pcv valve works as it is in the engine breather pipe that goes from the engine crankcase into the manifold
surely if this is faulty it would be like having a leak in the intake ie rough idling and cutting out
any suggestions?
cheers george
george
escort
Users browsing this forum: dumper
