3.73 rear axle????
Re: 3.73 rear axle????
Postby winterheating » Sat Feb 28, 2009 8:56 pm
ryzman wrote:
winterheating wrote:i would of thought with your power increase allready it will help a lot.
as youve allready got more power to weight than standard it shouldn't kill your acceleration.
i've just bought a 6 speed mondeo box for my van :!: :!: i can't wait to see the difference, and if it kills my accceleration, i'll just have to get the power up to match.
http://westfield-world.com/gtc.html
check this web site you can put ya details in to check speed... i put mine in and at 4500 van should do like 120mph :lol:
thats a good link
at 4000 my 125 tdci with 4.53 gearbox and 16'' rims will do 111mph (which is what it shows on speedo aswell)
but if i put original 15'' on it would lose 12mph @ 4000 (and my speedo use to be out by 10mph :!: :!: with 15''s on)
but if it had 15''s on
winterheating
Postby Paulscarbs » Tue Jun 11, 2019 7:27 pm
Any idea what the axle ratio currently is on an original Transit 2009, Duratorq TDCI 2.4 (100PS)?
Would this pull suitably with a 3.73 ratio axle - only be carrying 6 people and luggage?
Paulscarbs
Postby Jim Archer » Tue Jun 11, 2019 7:45 pm
Have a search for you vehicle on the Ford Etis sight. Put the Reg No or VIN in the Vehicle Search dropdown box.
You'll need to register to see all the As Built info.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby Paulscarbs » Tue Jun 11, 2019 8:04 pm
Thanks Jim, am I to find the axle ratio here?
I registered some time back but nothing axle related without payment as far as I can see!
Paulscarbs
Postby Airthies » Tue Jun 11, 2019 10:07 pm
If you registered it should come up in vehicle search in the "primary features" section
Sent from my anu5 using crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby andz327 » Tue Jun 11, 2019 10:42 pm
Is etis not hard to get into now due to this privacy law ballcocks
ANDZ
andz327
Postby Airthies » Tue Jun 11, 2019 10:56 pm
Justg noticed this thread is over 10years old
V86+patch
V86.04
X-Prog
C81
Airthies
Postby andz327 » Tue Jun 11, 2019 11:48 pm
Wondered aboot that maself mucker but checked date on yours and jim then joined in
ANDZ
andz327
Postby Paulscarbs » Wed Jun 12, 2019 8:04 am
Thanks Jim,
It’s a 5.11 axle.
Now, would the whole rig need changing or could the internal components be swapped?
Paulscarbs
Postby Paulscarbs » Sun Jun 23, 2019 10:50 am
Have a chance of getting a 3.58 axle. Hmm, unsure I'd have enough pulling power. Could somebody confirm?
Paulscarbs
Postby knobby1 » Mon Jun 24, 2019 12:59 am
Paulscarbs wrote:Have a chance of getting a 3.58 axle. Hmm, unsure I'd have enough pulling power. Could somebody confirm?
Methinks she may struggle a bit with a 3.58....especially with a load on. A mapped 140 will get away with it easily.
Postby Paulscarbs » Mon Jun 24, 2019 7:51 am
Thank you, that's confirmed my thoughts.
Paulscarbs
Postby EDDY99 » Mon Jun 24, 2019 7:59 am
Just changed my axle to a 3.73 and the van drives so much better.
My van is 100ps fully loaded campervan just over 3.25 ton.
The only problem I have had is getting onto leveling ramps but reversing onto them works fine.
MK 7 Transit 2006 (56) 2.4L Duratorq-TDCi (100PS) Series 1.7-350L
EDDY99
Postby Paulscarbs » Mon Jun 24, 2019 5:56 pm
Thanks, that's positive news.
Can axle ratios be established from chassis numbers?
Paulscarbs
Postby Airthies » Mon Jun 24, 2019 6:59 pm
Paulscarbs wrote:Thanks, that's positive news.
Not directly afaik.
But you can put in that vin no. Or reg. into Ford Etis and it'll tell you what it came out the factory with.
V86+patch
V86.04
X-Prog
C81
Airthies
