Did you think aboutEGR valve? It can be dirty and it gets locked i opened positio. EGR should be fully opened only on idle, later it shoud close very quickly. If EGR is still opened, you got a lot of dark grey smoke, no power, jerking. Correct, good idle.Colyer motorsport wrote:Just been and drain the fuel filter checked air filter all good started up runs like sh*t and lots of smoke
Frag wrote:Is the coil light flashing when it's faulty ?
Prone to water dripping onto top of engine / cylinder 1 injector electrical connection...
Frag wrote:Dry the area off,unplug and preferably blow out the plug and injector connections.
Refit it and see if that cures fault.
There should be a small orange seal where connector plugs onto injector,if this cures the poor running,then look into stopping water from scuttle leaking through...
