Off grid power?
Off grid power?
Postby thebarber » Fri Jun 28, 2019 7:20 am
I'm planning to do quite a bit of freeloading and want to charge my eleccy bike off grid via inverter, run fridge, lights etc. but was thinking of keeping leisure and van batteries separate to avoid discharging the van batt.
I'd probably be staying up to 3 nights in one place so thought solar was my only option but am reading about the B2B Chargers and how easy they are to fit.
Can anyone explain these in simple terms?
thebarber
Re: Off grid power?
Postby dumper » Fri Jun 28, 2019 9:21 am
Dead simple earth and live to van battery and the same to the leisure batteries with the earth lead you could earth it to the chassis but on mine nothing on the leisure side is earthed to van chassis it’s the same wireing for the cheap ones as the expensive sterling type but the sterling one charges quicker as for size it is a lot bigger
Re: Off grid power?
Postby thebarber » Sat Jun 29, 2019 7:29 am
Thanks, I've just looked at the sterling ones and there's a choice of 2.
12/12v 30amp and 12/12v 60amp
Would the 60 amp charge quicker or is it for more than 1 leisure batt ?
thebarber
Re: Off grid power?
Postby dumper » Sun Jun 30, 2019 2:17 pm
I got mine from 12 volt planet it’s the 30 amp one it charges two 120 amp batteries that are linked together so far I’ve no run them flat I use them to run all my 12v systems plus a 1500 wat inverter to run 500 wat microwave never more the 10 minutes in a day without running the engine and had no problems if you are going to park up fo longer the 60 maybe of more use to you 12volt planet are very helpful give them a ring they will be able to help when I had a question they gave me sterling’s number to give me advice give them a call :D
Re: Off grid power?
Postby thebarber » Sun Jun 30, 2019 9:28 pm
Great, thanks for the info
thebarber
Re: Off grid power?
Postby thebarber » Thu Jul 18, 2019 8:38 am
Still considering options here and found this...
https://www.photonicuniverse.com/en/cat ... eries.html
But doesn't seem to connect to van battery, not sure if I'd need to but would cover all situations then.
Waddya think of this, any experience ?
Cheers again.
thebarber
Re: Off grid power?
Postby dumper » Thu Jul 18, 2019 4:36 pm
That’s not cheap but I suppose my setup is about half that price and if the engine a running it is guaranteed to work will that be ok when the sun does not shine
Re: Off grid power?
Postby Carolsvan » Fri Jul 19, 2019 12:25 pm
thebarber wrote:Still considering options here and found this...
Cheers again.
HOW MUCH ?!
Carolsvan
Re: Off grid power?
Postby blue estate » Fri Jul 19, 2019 12:29 pm
Cheers again.
HOW MUCH ?!
Same thoughts as I wipe my tea off screen
blue estate
Re: Off grid power?
Postby thebarber » Sat Jul 20, 2019 7:46 am
Apparently the controller/inverter has a fan running so no good for sleeping compartment.
Found this tho that's B2B and solar controller...
https://www.simplysplitcharge.co.uk/ind ... uct_id=940
I still want solar to run fridge 24/7 and charge e-bike
Also found this 240v chest freezer which has a low setting allowing it to be used as a fridge, more economical to run than front door setup apparently
https://www.argos.co.uk/product/8834429
thebarber
Re: Off grid power?
Postby blue estate » Sat Jul 20, 2019 7:55 am
thebarber wrote:Apparently the controller/inverter has a fan running so no good for sleeping compartment.
What’s wrong with that ?
I have 2 compressor fridges in my cab and one has a cooling fan and it don’t bother me , traffic noise bothers me more
blue estate
Re: Off grid power?
Postby thebarber » Sat Jul 20, 2019 8:05 am
When the dude selling the product warns about issues I tend to listen, also the ring one pointed out to me does B2B so I can add an inverter to that.
thebarber
Re: Off grid power?
Postby EDDY99 » Sat Jul 20, 2019 5:09 pm
I used these people good quality and good price.
https://www.bimblesolar.com/
MK 7 Transit 2006 (56) 2.4L Duratorq-TDCi (100PS) Series 1.7-350L
EDDY99
Re: Off grid power?
Postby thebarber » Sun Jul 21, 2019 10:41 pm
Cheers, looked at their site and think the 320 lg panels cheep enough but don't have the charger/controller
thebarber
Re: Off grid power?
Postby Anthony1664 » Sun Jul 21, 2019 11:21 pm
Following this with interest, not wanting to hijack the post, anyone know if you can add a solar panel straight onto a CTek B2B charger or if you also need a solar panel controller ?
Anthony1664
