Fook me you've got her in bits already what's happened??Airthies wrote:Mine's way down the back at no.5 cylinderno need to remove anything
but it's clear to see when the manifolds no there
Sent from my anu5 using crapatalk
Just cleaning an fettlingandz327 wrote:Fook me you've got her in bits already what's happened??Airthies wrote:Mine's way down the back at no.5 cylinderno need to remove anything
ANDZ
Your up tae nae guid sir I'm keeping an eye on youAirthies wrote:Just cleaning an fettlingandz327 wrote:Fook me you've got her in bits already what's happened??Airthies wrote:Mine's way down the back at no.5 cylinderno need to remove anything
ANDZ![]()
Karst wrote:The bag of bones started kangarooing again so I took the Crown Prosecution Service out and found some gack on it again Wiped it off and put it back in, let's see what happens.
Good try sir but wrong check first post when we congratulated him, only noo we know what the post was abootknobby1 wrote:Karst wrote:The bag of bones started kangarooing again so I took the Crown Prosecution Service out and found some gack on it again Wiped it off and put it back in, let's see what happens.
And what might this "Crown Prosecution Service" be doing then..??![]()
If there's gunk all over it I suspect your DMF may be failing.
Punto443 wrote::D
andz327 wrote:Good try sir but wrong check first post when we congratulated him, only noo we know what the post was abootknobby1 wrote:Karst wrote:The bag of bones started kangarooing again so I took the Crown Prosecution Service out and found some gack on it again Wiped it off and put it back in, let's see what happens.
Lord Knobrotoh and 85ps dont huv DMFs
ANDZ
bambi mk 1 wrote:Good try sir but wrong check first post when we congratulated him, only noo we know what the post was abootandz327 wrote:knobby1 wrote:[quote="Karst"]The bag of bones started kangarooing again so I took the Crown Prosecution Service out and found some gack on it again Wiped it off and put it back in, let's see what happens.
ANDZ
Users browsing this forum: Trev_
