Axle ratio code help
Postby phorbiuz » Sun Jul 07, 2019 1:09 pm
Hi all
It's been some time since I was last on here, so it's good to see the forum still alive and healthy. I'm hoping someone can help again please.
My mk2 AutoSleeper is based on an '85 100 model, originally a 2.0 mated to the standard 4 speed manual. The VIN plate states I have rear axle type B, ratio E. I can't find any reference anywhere to ratio E, so can anyone enlighten me as to what it is? There is no tag on the housing.
Thanks.
phorbiuz
Re: Axle ratio code help
Postby phorbiuz » Wed Jul 10, 2019 8:29 am
I presume this has all our experts stumped then?
Dave.
phorbiuz
Postby DougT » Thu Jul 11, 2019 1:27 pm
If it is the same coding as for the Mk1, then axle ratio E would be 5.86. But i don't have any info for the Mk2.
Again, if it is the same as the Mk1 then axle B would be the 1550kg axle.
I think you will have to test the axle by rotating the propshaft with a wheel off the ground and counting the relevant number of turns in order to make sure.
Doug
DougT
Postby wojciech » Sun Jul 14, 2019 9:27 pm
phorbiuz wrote:I presume this has all our experts stumped then?
Dave.
Mk2 can be fitted with three different axles, typ F, G and H - look fo pictures in link https://www.capri.pl/image/manuals/tran ... /15/15-002
Their ratio you can find in link https://www.capri.pl/image/manuals/tran ... /15/15-003
All manual for Mk2 https://www.capri.pl/image/manuals/tran ... /15/15-003
All their library https://www.capri.pl/library/#movies
phorbiuz wrote: The VIN plate states I have rear axle type B, ratio E.
Propably "B" it is gearbox (manual, 4 gears), "E" it is rear axle 4,44:1 Timken. But I'm not sure for 100%.
wojciech
Postby Neil » Mon Jul 15, 2019 7:11 am
I think the swb would be either a Timken or Salisbury ?? one is round caseing the other square
Neil v6
Neil
Return to Mk 1 & 2
