Jim Archer wrote:Me side exit exhaust plan is moving forward, therefore I'm after the short piece of pipe and flange that is welded on the front of the stock silencer (or aftermarket if larger than Ø60.5mm O/D) and the wiggley section that goes over the rear axle.
Not too bothered if a bit scabby as using to mock up, as long as it's solid enough to be able to swage/expand and/or weld.
Jim
Jim there's plenty new pipe bits bends straights etc on ebay really cheap ,probably everything you need , i replaced the flexy and its quite a big yin and was only aboot 10 sheckles and it was slotted so straight pipe would fit if you were wanting to do away with the flange, , i maybe doing away with ma silencer altogether in the near future with the pipe coming out the side down nearer the rear wheel
ANDZ
