Door pocket
Door pocket
Postby dirtydog » Sat Aug 03, 2019 3:14 pm
Anyone got a spare Mk6/7 door pocket?
dirtydog
Re: Door pocket
Postby loot » Mon Aug 05, 2019 7:40 pm
Which 1 mate? The lower 1 as in the mod?
I used mine the other day but I have 2 spare doors, both left and I think some right door bits too like glass and quarter, also a mix of electric and manual winder.
07 350 170ps
Ids map here
loot
Re: Door pocket
Postby Altransit » Mon Aug 05, 2019 7:42 pm
I've been after one of those lower pockets for ages, they go for stupid money on ebay :roll:
Re: Door pocket
Postby loot » Mon Aug 05, 2019 7:44 pm
:shock:
Its just a left door pocket fitted on the right 8) I suppose you might get a lhd pocket that fits but this is great.
07 350 170ps
Ids map here
loot
Re: Door pocket
Postby ned » Mon Aug 05, 2019 7:45 pm
I have a lower pocket, only cost me 5 sovs :wink: ok so it's a passenger door pocket fitted to the driver's door but it does the job :D
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Re: Door pocket
Postby loot » Mon Aug 05, 2019 7:48 pm
Certainly does, all i did on the front bit is cut a bit off the original door card and cut a bit off the pocket so it kind of locks inside them screw through them both. Apart from that it fits perfect. Just make sure you get the square clips as they push into square holes behind the blanks or it'll never go on. :?
Don't know why they are rare lol
07 350 170ps
Ids map here
loot
Re: Door pocket
Postby ned » Mon Aug 05, 2019 8:09 pm
Square clips? You lost me, I just trimmed a wee bit off the front of mine so it fits over the door card a bit then screwed it in with 4 screws :P
Shame mine is full of useful junk like stick on wheel weights, fuses, invoice book, and unknown amount of receipts :lol:
ned
Re: Door pocket
Postby bambi mk 1 » Mon Aug 05, 2019 9:17 pm
loot wrote:Certainly does, all i did on the front bit is cut a bit off the original door card and cut a bit off the pocket so it kind of locks inside them screw through them both. Apart from that it fits perfect. Just make sure you get the square clips as they push into square holes behind the blanks or it'll never go on. :?
Must be because I have about 50 :mrgreen: £100 each any takers :?: :lol:
bambi mk 1
Re: Door pocket
Postby Altransit » Mon Aug 05, 2019 9:36 pm
bambi mk 1 wrote:Must be because I have about 50
Yes, it's you hoarding them that's causing the shortage :roll: :P :lol:
Re: Door pocket
Postby loot » Mon Aug 05, 2019 9:53 pm
:lol:
07 350 170ps
Ids map here
loot
Re: Door pocket
Postby loot » Mon Aug 05, 2019 9:54 pm
You screwed into the black plastic blanks Ned? :lol: fair play if it works 8)
07 350 170ps
Ids map here
loot
Re: Door pocket
Postby ned » Mon Aug 05, 2019 10:22 pm
loot wrote:You screwed into the black plastic blanks Ned? :lol: fair play if it works 8)
:lol: no it didn't line up with them irrc so I drilled the door and used self tapping screws, t'was a while ago when I did it.
ned
Re: Door pocket
Postby dirtydog » Mon Aug 05, 2019 10:41 pm
loot wrote:Which 1 mate? The lower 1 as in the mod?
Yeah the bottom one, extra storage is always useful!
dirtydog
Re: Door pocket
Postby dirtydog » Mon Aug 05, 2019 10:44 pm
I've seen the square clips, some bloke is selling a pack of 20 on eBay for nearly £30. Need to measure the square holes so I can just buy some generic ones
dirtydog
Re: Door pocket
Postby loot » Tue Aug 06, 2019 7:52 am
30 quid :shock: yes generic ones will be 99p for 500 8)
07 350 170ps
Ids map here
loot
