2.5 diesel Lucas error codes
Postby zoist » Wed Sep 11, 2019 9:22 am
Just wondering if someone could please tell me what these codes mean and if it's important.
Thanks.
P1171 Rotor sensor
P1173 O2S-inversion
P1178 Bolt-up limits
P1170 Engine shut off solenoid
Should I be worried about these. They don't put the engine light on.
zoist
Re: 2.5 diesel Lucas error codes
Postby Jim Archer » Wed Sep 11, 2019 9:47 am
Which reader/scan tool where they obtained with? Only the dedicated EPIC readers can be relied upon to give accurate codes.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby MinorMatt » Wed Sep 11, 2019 11:35 am
Definately not a laser 2000 from the description.
At least 3 of those codes would put the management lamp on, so they are either historic or someone has fudged the lamp...
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby zoist » Thu Sep 12, 2019 6:18 am
Hi, just had a code P1174 - Cam Sensor come on today, in limp mode.
I'm using a laptop with the forscan software.
Thanks.
zoist
Postby MinorMatt » Thu Sep 12, 2019 4:22 pm
New injection pump is the fix for that one...
93 L GL Minibus
Postby zoist » Fri Sep 13, 2019 12:03 am
It's a new reco.
zoist
Postby MinorMatt » Mon Sep 16, 2019 11:58 am
Its obviously not been done correctly then...
93 L GL Minibus
