MK 6/7) turning off the service light?
Re: MK 6/7) turning off the service light?
Postby loot » Sat Feb 06, 2016 11:33 am
You press the brake and accelerator down hard, turn the ignition to pos2 and wait till the light flashes (high spec clocks say resetting)
loot
Postby rogerw » Wed Feb 17, 2016 1:08 pm
Doesn't work one mine cos it's a petrol .
rogerw
Postby loot » Wed Feb 17, 2016 5:10 pm
Out of interest, what's the difference? Ok mileage intervals maybe but the procedure would be the same surely?
loot
Postby Cheese Monkey » Tue Sep 27, 2016 2:27 pm
What triggers the service light to come on? A set mileage since it was last reset? Mine has only done 3-4K since last service at Ford
Cheese Monkey
Postby ake » Thu Sep 29, 2016 6:02 pm
Cheese Monkey wrote:What triggers the service light to come on? A set mileage since it was last reset? Mine has only done 3-4K since last service at Ford
It's a mileage counter, unless it's a 140 or 200 with oil sensor
Postby Cheese Monkey » Thu Sep 29, 2016 9:31 pm
Is a 2011 350 140, do they all have oil sensors? Hasnt come back on since I reset it
Cheese Monkey
Postby Cheese Monkey » Fri Sep 30, 2016 9:21 am
Been fine over last few days. I'm guessing the service light came on due to mileage, not oil quality? I would guess it does both?
Cheese Monkey
Postby Havoc99 » Fri Sep 27, 2019 9:14 am
Hi guys
Turning off service light problem. Maybe you guys can assist. Thanks
2004 transit minibus mark 6
2.4 duratorque
Have tried turn ignition on
Press brake & accelerator fully
Wait........... Have waited over a minute
But the service light spanner does not flash as expected
I'm stumped
Any advice really appreciated
Cheers guys
Havoc99
Postby Havoc99 » Fri Sep 27, 2019 4:35 pm
Have tried pressing brake & accelerator before turning ingnition on, sadly service light still stays on & does not start flashing
Havoc99
Postby Havoc99 » Fri Sep 27, 2019 5:51 pm
Have also checked oil level & toped up approx 2L
It's spot on now.
Could the service light be on for some other reason ??
Do any filters etc etc have end of life sensors on them or anything like that.
I did a long journey for me 200 miles the day before the sevice light spanner came on.
Cannot seem to reset it.
Help.......... LOL
Havoc99
Postby Havoc99 » Fri Sep 27, 2019 6:21 pm
Ok seems side lights are ok, but the brake lights are not working on either side.......
Havoc99
Postby Havoc99 » Sat Sep 28, 2019 12:00 pm
Ok so took foot brake switch apart cleaned the crap of the contacts & bingo, I have rear brake lights again.
Tried to reset the service spanner light (with side lights on & all doors closed)
BINGO, service light reset & off.
CHEERS FOR ADVICE FOUND EARLIER ON THIS THREAD
Havoc99
Postby Stumble » Sat Jun 06, 2020 5:50 pm
As I have just changed my MK7's oil & filter - no service indicator showing - I though I'd try to reset it so it won't come on too early
Mine is a boggo spec so just a flashing spanner came up, not sure if I actually reset it - anyone know if it can be before it actually shows ?
Also what is the supposed oil change interval ? Haynes says 7500 miles ?
Stumble
