Mk2 pinto to early di conversion
Postby Luke » Sat Jul 07, 2007 10:58 pm
Retrohowla wrote:do you know anything about the wiring from petrol to diesel?
yes :D - its a piece of piss :lol:
Postby Retrohowla » Sat Jul 07, 2007 10:59 pm
so apart fro, a switched live to the fuel solenoid, is that right?
What about alternator to loom?
If you own a transit, learn to weld
Retrohowla
Postby Luke » Sat Jul 07, 2007 11:03 pm
Retrohowla wrote:so apart fro, a switched live to the fuel solenoid, is that right?
yep :D and alt to loom is exactly the same - the only thing different is later Di's have a starter solenoid relay, ie a relay that operates the starter solenoid - rather than direct :D
Postby Retrohowla » Sat Jul 07, 2007 11:09 pm
Magic! fairly sure mine is direct feed to started solenoid so happy days
so with the prop on the mk2 if i cut off the di prop end machine it true and have it welded to the mk2 prop (@ correct length) is it pretty simple from here?
gbox mounting plate/member from 92 onto mk2 yes?
cut out new hole for shift stick in floor?
then i need a fuel return to the tank, mount header tank and rad, much else?
Retrohowla
Postby Luke » Sat Jul 07, 2007 11:14 pm
Retrohowla wrote: when i changed the bloody prop it was a bolted flange so its mt75?
do you allready have an mt75 - if so you wont need to touch the prop or box :D
Postby Retrohowla » Sat Jul 07, 2007 11:17 pm
Sorry i am chopping and changing, i have a 92 swb with di and mt75
i plan to use this as a donor for my 1981 lwb pinto 4 speed
i.e. scrap th pinto and 4 speed and fit di and mt75 into mk2
am i making any sense?
Retrohowla
Postby Luke » Sat Jul 07, 2007 11:21 pm
right yes :lol:
to do a pukka job you can chop the bit of the floor out of the mk4 and weld it into the mk2 :D
Postby Luke » Sat Jul 07, 2007 11:23 pm
this bit :D
you'll find it fits the mk2 floor perfectly :D
Postby Retrohowla » Sat Jul 07, 2007 11:24 pm
Right, so is this to make room for the box or to allow shift stick to come through?
and with regards to the prop am i somewhere handy with what i plan to do?
Retrohowla
Postby Retrohowla » Sat Jul 07, 2007 11:25 pm
Love it
blue peter styleee
:D
Retrohowla
Postby Luke » Sat Jul 07, 2007 11:26 pm
wherabouts are you :?: - you can put it in your profile :wink:
Postby Retrohowla » Sat Jul 07, 2007 11:27 pm
southampton
i will try and update
where do i start
i am a bit slow!
Retrohowla
Postby Luke » Sat Jul 07, 2007 11:27 pm
Retrohowla wrote:Right, so is this to make room for the box or to allow shift stick to come through?
make room for the box - it will fit without it but only just - best do this especially if you have a donor van :D
Postby Luke » Sat Jul 07, 2007 11:31 pm
you'll also need to slightly mod the the mt75 cross member as its off a swb van :D do you have a welder :?:
Postby Retrohowla » Sat Jul 07, 2007 11:32 pm
Any more info i should put in profile?
Yes i follow, makes sense as i have the donor, would it be wise to match the diff to the engine and box or no need?
so to recap, replace tunnel for later to fit mt75, gbox x-member bolt straight in or do i need to redrill of fabricate new mount?
engine go straight on pinto mounts?
it your brain frying yet cos mine is!! :?
Retrohowla
Return to Mk 1 & 2
