1994 150D SWB - Can I easily change the diff ratio?
Postby bp_williams » Thu Nov 24, 2005 9:31 am
Hi fellas,
I just bought an old Transit and it only seems to want to cruise at 60mph. I can get 70 out of it, but it sounds like the lump wants to jump out and run away. Is there a cost-effective way to up the ratios to give a better motorway cruising speed?
Brendan
bp_williams
Postby bp_williams » Fri Nov 25, 2005 12:24 pm
Just to add what I was getting at. Is there an easy way to swap another diff either in part or full? Any particular model?
bp_williams
Postby madmark » Fri Nov 25, 2005 1:22 pm
brendan no mate its a nightmere of a job unless you can find somebody that now,s about them , it uses the same type diff as the twin wheeler, you will probly have ratio 5.14 or 5.63 you need 4.63 this is as low as you can go!
Postby Luke » Fri Nov 25, 2005 1:27 pm
The easyest way would be to swap to a 5 stud axle! :?
but then you would have different wheels on the front to the back - not illegal just awkward carring 2 spares!! :lol:
Postby bp_williams » Fri Nov 25, 2005 1:29 pm
The tyres are sh@gged on the back anyway, so may try to get a higher profile as a noddy-solution and live with it. It's just a sh1tter, so perhaps if I end up doing any more motorway miles, I will have to upgrade!
:idea: Cheers
bp_williams
Postby madmark » Fri Nov 25, 2005 7:40 pm
when you upgrade whatch for rust get undernieth mate! :?
Postby Boycie » Mon Nov 28, 2005 11:00 am
I've got a 4:63 in my 150 SWB mate... it's a happy medium... perfectly nippy round town and I've managed 100mph before.
Happily cruises at 80 though.
Boycie
