Reverse switch and gearbox
Postby loot » Mon Sep 23, 2019 5:52 pm
Just a quick 1 lads, my reverse switch works and the wiring does too however when I select reverse the lights don't come on :?
Can't find much, debating whether I should remove my selector and service it but does anyone know if it is a common thing that the pin breaks or just stops pushing on the switch at the selector for reverse?
07 350 170ps
Ids map here
loot
Re: Reverse switch and gearbox
Postby Murphanator » Wed Sep 25, 2019 1:16 am
I’ve had the same problem with 2 different reverse switches on two mark6 vans. I just take them out and service them each time they start to fail..I think the ballbearing switch doesn’t get much rotation when the pin hits it.
I just rotate the ballbearing, then check it’s working again with a multimeter, works every time for me..
It’s never been the pin that’s broken.
Murphanator
Postby loot » Wed Sep 25, 2019 8:13 am
Cheers.
Mine is the plastic plate type with a breather on it.
07 350 170ps
Ids map here
loot
Postby Transitpartsuk » Wed Sep 25, 2019 8:25 am
If you want I can see if i have a spare one of those laying around?
Transitpartsuk
Registered Trader
Registered Trader
Postby loot » Wed Sep 25, 2019 10:07 am
That would be great :D
07 350 170ps
Ids map here
loot
Postby Transitpartsuk » Mon Oct 07, 2019 1:03 pm
Is this still needed mate? Think I have just had one in
Transitpartsuk
Registered Trader
Registered Trader
Postby loot » Mon Oct 07, 2019 1:42 pm
Hi I still don't have any reverse lights, I'm not sure if it is the switch or the pin inside the gear selector that is at fault though. Thanks
07 350 170ps
Ids map here
loot
Postby Transitpartsuk » Mon Oct 07, 2019 2:31 pm
No worries, PM me your address and I will send one out to you.
Transitpartsuk
Registered Trader
Registered Trader
Postby loot » Mon Oct 07, 2019 3:34 pm
Pm sent thanks.
07 350 170ps
Ids map here
loot
Postby Logan848 » Tue Oct 08, 2019 7:27 pm
I had the same thing checked everything but couldn’t find problem until I stuck my inspection camera into gear box where switch came out and found the pin had come loose and fallen out, screwed it back in sorted everything out, hope this helps :D
Logan848
Postby loot » Sat Oct 12, 2019 4:34 pm
Now then, thanks to transitpartsuk for the switch but it wasn't the problem, the pin as mentioned above was in and thought and intact but I guess the combination of wear on the main shaft seal allowing it sideways play and the pin being worn caused it to not press the switch in enough.
I cleaned and greased it all. I removed the pin and found 2 aluminium rivet drilled out bits that looked like mini washers and used then to keep the pin further out. They work well.
Everything looks OK other than that.
07 350 170ps
Ids map here
loot
Postby Transitpartsuk » Thu Nov 14, 2019 1:26 pm
We recondition these ourselves. It is pretty easy to do. Ford sell the bearings shims and everything you need for not much money.
Transitpartsuk
Registered Trader
Registered Trader
Postby loot » Thu Nov 14, 2019 1:34 pm
Cheers, my issue is with first and second when cold, after that it is reasonably fine. I'm thinking oil or synchros aren't happy.
Not thinking cables as it is OK when warm :(
07 350 170ps
Ids map here
loot
