Manual to Auto transmission help please
Postby Minxy » Sun Oct 07, 2018 5:42 pm
Hi people. Can anyone tell me what is involved in changing a Mk1 transit with a manual gearbox, to automatic. The engine on the Mk1 van is very good, its a 2 litre petrol pinto.
I would like to know if its possible to keep the original engine and change whatever is needed for it to be automatic transmission. Or is there a whole load of parts to change over ? eg is it better to find a whole donor van and straight swap, then sell the donor van on ?
Yes I know the logic is ' find what you want' but I can't find one with the age and bosy type I'm after. I hate the new transit shape, and I want a Mk 1 so it will be tax exempt as it would be a second vehicle.
I hope one of you out there is nice enough to help with info, cheers :)
Minxy
Re: Manual to Auto transmission help please
Postby Ralph.9 » Sun Oct 07, 2018 9:06 pm
I have a new MK1 auto box for a V4 with the pedal box & dash changer. You won't find a MK1 auto box to fit the pinto as it was not an original fitment.The Mk1 boxes are top hung at the rear.
Ralph.9
Postby Minxy » Mon Oct 08, 2018 2:07 am
Ralph.9 wrote:I have a new MK1 auto box for a V4 with the pedal box & dash changer. You won't find a MK1 auto box to fit the pinto as it was not an original fitment.The Mk1 boxes are top hung at the rear.
Hi Ralph, I made a mistake, its a Mk2 transit, with a pinto engine and a manual gearbox. does that make any difference ?
Minxy
Postby conrod » Mon Oct 08, 2018 4:08 am
Mk2 is much easier to convert. You can use an automatic from a Cortina or Capri with a 2.0 Pinto. You will need the flexplate, torque converter, and transmission of course. Transit specific parts are the crossmember/mount, and the shifter, which was quite long for the Transit.(I have one of these, but being in NZ postage would be huge!) Not sure if the propshaft was different. Diff ratio was generally a bit taller on the automatics too. Again Ralph is probably your man for these parts. :)
conrod
Postby Neil » Mon Oct 08, 2018 6:59 am
yes its an easier swap the selector is thru the floor if you can find a breaker as the carb will have different linkages for the kick down cable etc ,,most transits use the ford gearbox but there are odd ones with the borg warner box in
Neil v6
Neil
Postby dumper » Mon Oct 08, 2018 8:59 am
Not 100% long time ago but we had a automatic the gear change was on the dash but it also had a oil cooler pipe that when into the bottom of the radiator and back to the box I once did conversion outher was round and had to rejet the carb
Postby Minxy » Mon Oct 08, 2018 4:47 pm
Hi Guys thank you for all the info, the selector gearstick is definitely mounted on the floor in the van, so I'm hoping thus means its possible. If anyone can help with more specifics id appreciate it. meanwhile will PM Ralph :)
Minxy
Postby Neil » Mon Oct 08, 2018 6:14 pm
Minxy wrote:Hi Guys thank you for all the info, the selector gearstick is definitely mounted on the floor in the van, so I'm hoping thus means its possible. If anyone can help with more specifics id appreciate it. meanwhile will PM Ralph :)
yes mk 2 are on the floor and mk 1 were on the dash
Neil v6
Neil
Postby skerr3 » Sat Oct 12, 2019 6:15 pm
Hi, Ralph.9, you mentioned that you had a V4 auto box and dash changer, do you still have them available?
New user, can't yet send PM
skerr3
Return to Mk 1 & 2
