DETAILS OF YOUR VAN? OFF 7.ZAP
Re: DETAILS OF YOUR VAN? OFF 7.ZAP
Postby Jay2018 » Sat Sep 14, 2019 9:38 am
It's working now... :D
2012 MK7 Transit Trend 125 T350 6 SPD FWD MWB MR (Frozen White) :D
2010 MK7 Transit Jumbo 100 - SOLD :(
Galant VR4 8th Gen Type S(TT), 300ZX(TT) + S14A(T), Supra MK3(T), Golf MK4 1.8(T), GS300 & Civic EG9 VTI (ALL SOLD)
Jay2018
Postby Airthies » Thu Sep 19, 2019 1:02 pm
Is there any easy handy ways of finding out VINs using the Reg no. Other than through etis? Would be handy when perusing the aisles of preloved parts still attached to their exoskeletons.
I can't remember my etis login
Sent from my anu5 using crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Thu Sep 19, 2019 2:41 pm
You don't need etis log in, just go to etis put the reg in then scroll down to the vin and copy it then come here and paste it in and that's it. Still more than we want to do but is easy enough 8)
07 350 170ps
Ids map here
loot
Postby Airthies » Thu Sep 19, 2019 2:46 pm
loot wrote:You don't need etis log in, just go to etis put the reg in then scroll down to the vin and copy it then come here and paste it in and that's it. Still more than we want to do but is easy enough 8)
Ah yes silly me oops forgot it showed on the tramps page
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Mc Nasty » Sun Oct 27, 2019 8:28 pm
Dodge20 wrote:Doesn't work with my van :cry:. It tells me it's a custom then requires me to input all details such as build date, paint colour, interior trim etc etc.
Same here, typed vin in just said TT9 Is it me? or has it stopped working?
Mc Nasty
Postby loot » Mon Oct 28, 2019 10:33 pm
Type the vin in and then it shows the model to select which when you click on it out then opens up all the build info.
07 350 170ps
Ids map here
loot
Postby Mc Nasty » Tue Oct 29, 2019 3:11 pm
loot wrote:Type the vin in and then it shows the model to select which when you click on it out then opens up all the build info.
Had done, the issue was a 0 inputted as a O gave a partial return rather than an error. got it now thanks.
Mc Nasty
Postby shortymk6 » Mon Nov 18, 2019 11:16 pm
Where can you enter the reg please?
shortymk6
Postby loot » Tue Nov 19, 2019 9:30 am
Put the reg into http://www.etis.ford.com/vehicleRegSele ... ccvas1900a
It then returns free basic info of the vehicle including its vin number that you can copy and then come to here and in 7zap you paste the vin into the box and that brings up all the info.
It is useful if you are looking to buy a vehicle that you don't know the vin of.
Otherwise on your vehicle just get the vin and come straight here.
07 350 170ps
Ids map here
loot
Postby shortymk6 » Tue Nov 19, 2019 1:16 pm
thank you i couldnt see it for looking
shortymk6
Postby andz327 » Sun Dec 15, 2019 12:02 am
loot wrote:Additional options:
Complete Vehicle
Less MPH Engine Governor
Less Rear Seat Armrest Packs
With Tunnel Mounted Parking Brake
With Single Rear Wheels
Less Float Mounting
Less Temp Control Passengers Seat
Less Side/Rr Door Security Lockset
Less Rear Compartment Trim Panel
Less Seat/Airbag Pack
Less Smokers Package
Less Trim Pack
Less Passenger Seat Armrests
Less Engine RPM Control
Less Heated Rear Window
Less Auxiliary Fuse Panel
Less SVO Application/Label
Less Rear Stabilizer Bar
Less Dual Rear Wheel Pack
Less Diesel Fuel Cooler
Less Passenger Seat Valance
Less Battery Cut Off Relay
Less A/C Unit - Roof Mounted
Less Temp Control Driver Seat
With Black Air Vent Knob
Less Roof Flasher Wiring
Less 2nd Row RH Side Window
With Visibility Pack
With Rear Mudflaps
With Heated Windscreen
With Column Stalk Radio Controls
With High Mounted Stop Lamp
With Spare Tyre Security Package
Less Auxiliary Heater
With Front Towing Hook
Marketing Flex Prep Pack 1
With Instrument Panel Dimmer Switch
Less Passenger Air Bag
With Load Space Tie Down Loop
Less Optional Equipment Pack
Less Rear Window Protector
With Trip Computer
Less Rear Window Wiper/Washer
With Power Equipment Group
With Drivers Seat Fixed Armrest
Rain Sensor - Fr Windscreen Wiper
With Front Roof Grab Handle
Less Rear Seat Belts
With Manual Headlamp Levelling
With Dual Side Load Doors
With Power Front Windows
European Environmental Label
Blue Tooth Interface Connect
With MPH/KMH Speedometer
With Automatic Headlamp On/Off
Fuel Water Separator Less Sensor
Extra Heavy Duty Battery
With Telephone Prep Pack - Design B
With Front Fog Lamps
Cold Start Up To -20%c
Marketing Level 3
Seat Pack 22
Electronic Stability Brk Ctrl (ESP)
Less Transfer Case
With Recirculating Heater
With Rear Blanking Panel
With Door Dead Locks
Less Adjustable Passenger Seat
Remote Control Door Entry - 2 Fob
Voice Activated Module - British
With Full Wheel Cover
Power 4-Wheel Disc Vacuum Boost
4 Wheel Anti-Lock Braking System
With Full Partition - Steel
With Driver 6 Way Mnl.Seat Adjuster
Less Rear View Mirror
Ice Feature Pack 3
Large Head/Short Arm Mirror
Less 2nd Row Rear Seat
With All Light Tinted Glass
With Sngle.L/B Dvr/Dual L/B Pass.St
RHD FWD
Front Bumper Body Coloured Plastic
Otosan (Turkey) Plant Build
LX Sales Badge
Stage IV Emissions
4.54
Lichen
Regular Cargo Van
(+)"GB"
350M Series
Transit 2006-
2.2L Duratorq-TDCi (130PS) - Puma
Moondust Silver (Metallic)
Tomy (G-C)
Don't they all hsve tunnel mounted parking brake,????
Sent from my SM-G975F using Tapatalk
andz327
Postby andz327 » Sun Dec 15, 2019 12:03 am
loot wrote:Certainly does :P
Auld Bettsie is asbos little sister
andz327
Postby loot » Sun Dec 15, 2019 4:38 pm
8)
I've read that some campers have the handbrake on the right side of the driver seat to allow swivel, but that may be an addition from a coach builders, you do see some options in config that do seem standard and obvious though :lol:
07 350 170ps
Ids map here
loot
Postby dumper » Sun Dec 15, 2019 4:59 pm
loot wrote:8)
Somewhere on the forum their is a post with photos for the right hand handbrake and it shows the bracket with ford logo and part numbers but was a long time ago
Postby DHTBX61EKK » Thu Jul 02, 2020 2:56 pm
Phew, just looked up details of my van from 7.ZAP
226 lines of info, this is going to take awhile to go through. I have copied into Exel and will let you know how I get on.
DT
DHTBX61EKK
