Immobiliser code 13 new key worked then stopped???
Postby AnarcoDave » Sun Nov 03, 2019 6:05 pm
Hi folks
As the subject says I have a mk6 Transit LWB 2.4 ... with immoiliser problems
Iv had the old girl for about a year and a bit, she doesn't have a hard life mostly the occasional run around with bits of furniture every few weeks. She realy is my pride and joy I love er! :D ...I plan to do a camper conversion on her at some point so it is definetly a project as opposed to a working vehicle ....
Anyway about a week ago the immobiliser stopped recognising the key all of a sudden I got the repeated flashing then a code 13. So I got a new key cut and programmed and that worked !! joy :D :D
.... went out to start her up the next day .... same problem with the new key
So now I guess it must be a fault with the transponder or ecu witch means a major hassle for me right?
At the end of the day I would if I could just bypass the whole immobiliser system I understand thats not the kind of info to publish on a public forum..... but it'd be a great option for me so if anybody can point me in the right direction Id be greatfull
Otherwise can anybody advice me of any other options?
I will not be giveing up on this van so whatever it takes... !
Thanks in advance
Dave
AnarcoDave
Re: Immobiliser code 13 new key worked then stopped???
Postby AnarcoDave » Tue Nov 05, 2019 1:31 pm
I have Forscan and a ELM327 USB Diagnostic Tool on its way . I dont know if this will help diagnose anything but useful tool to have non the-less
AnarcoDave
Postby Altransit » Wed Nov 06, 2019 8:38 pm
:idea: Have you checked the receptor ring around the ignition barrel (which picks up the key signal) or the wiring to it :?:
Might be worth a look :mrgreen:
Postby AnarcoDave » Thu Nov 07, 2019 12:04 pm
Is the receptor ring programed to the ecu?
AnarcoDave
Postby Altransit » Thu Nov 07, 2019 3:40 pm
AnarcoDave wrote:Is the receptor ring programed to the ecu?
Nope :)
Postby AnarcoDave » Fri Nov 08, 2019 1:24 pm
Really?.. I can't find a receptor ring that doesnt need to come as part of an ecu kit.
Are we talking about the same thing... The transceiver that receives the signal from the chip in the key?
As far as I can see if I can't solve this problem I will need to buy a new ecu, barrel, key and teansever ring replace all of them and then get the fuel pump coded to the new ecu.. I hope I'm wrong and if anybody has any suggestions...?
AnarcoDave
Postby davyjcb » Fri Nov 08, 2019 6:03 pm
The ring is clipped onto the ignition barrel just behind the cover . The ring is not coded as such it just picks up the info from the key chip and transfers it to the ecu
96 escort 55 van gone
98 smiley mwb semi high gone
01 90/350 mwb semi high roof gone
05 135/350 lwb semi high roof gone
10 85/260 swb low roof leader gone
09 140/350 lwb semi high fwd
11 115/330 mwb semi high roof
davyjcb
Postby AnarcoDave » Fri Nov 08, 2019 6:25 pm
So I can buy one off the shelf or take one from another van?
Has anyone heard off flat battery's cousin imobiliser to kick in?
AnarcoDave
Postby Altransit » Fri Nov 08, 2019 11:21 pm
Flash code 13 means there is no code received from the key, so the likelyhood is that the receiver isn't working, or the key is dud.
With any electrical gremlin, it's always worth making sure that the main battery is in good condition, and fully charged :idea:
Postby AnarcoDave » Sat Nov 09, 2019 8:59 am
Well that's a relief!
Battery charged, problem solved!
AnarcoDave
Postby AnarcoDave » Sun Nov 10, 2019 11:27 am
OK back to square one...
I charged the battery originally for 5 hours put it back into the van and everything worked, van started fine no immobiliser.
So I went out and noticed a light on the dash(green back lights on clock and odometer) thinking aah! so I have a parasitic drain...
I took my battery out and charged it over night , went out this morning with what I believe is a fully charged battery
Note this battery is nearly new I got about 6 months ago brand new...
aaaand the immobiliser is doing the same thing as before
wont even kick the starter motor and flashes code 13
can anybody give me any advice?
Im getting the multi metter out as we speak but I dont really know what Im checkin for ...
I guess volotage from the battery ...
help!
AnarcoDave
Postby AnarcoDave » Wed Nov 13, 2019 7:55 am
Hi folks
After a PATS module initialization useing Forscan I seem to have solved the problem of the key's not being recognised but now the van trys to start but dies immediately like the feul pump isn't pumping.... Any suggestions?
Davie
AnarcoDave
