Mk5 parts needed
Mk5 parts needed
Postby jamie182 » Sat Nov 02, 2019 7:20 pm
Hi I need a couple of parts only small but I don't mind paying enough to make it worth your time.
First thing I need is the clip that goes on the Injection pump end of the throttle cable Item 14 on the diagram
Then I need the propshaft center bearing mounting bracket I need to fit the part that bolts to the bottom of the van with 4 torx head screws (and the 4 screws as mine aren't it a good way)
I have a propshaft from a swb mk5
It's going into my 1992 mk4, my current one is to far back to accept the mk5 prop, the center support needs to bolt on about 100mm forward my current bracket looks like item 6
Looks like I need item 8 to make it fit correctly
If anyone can help with any of these I'll be very grateful.
jamie182
Re: Mk5 parts needed
Postby jamie182 » Mon Nov 04, 2019 9:01 pm
I have managed to get the propshaft support bracket.
I still need the clip for the fuel pump control cable.
Also could do with a boost pipe from a 85/100hp transit the later type that goes to the front of the manifold with egr.
jamie182
Postby MinorMatt » Fri Nov 08, 2019 11:34 pm
Those clips arn't expensive at Ford...
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby jamie182 » Fri Nov 15, 2019 11:55 pm
i got one from ford in the end was £8 ish
jamie182
cron
