Mk7 trailer wiring kit for use with parking sensors
Postby Airthies » Tue Jun 25, 2019 11:20 pm
Looking at fitting a genuine trailer kit since this mk7 has parking sensors.
What's available? Does anyone have the wiring harness laying around?
Or a good source other than Ford?
Sent from my anu5 using crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: Mk7 trailer wiring kit for use with parking sensors
Postby loot » Tue Jun 25, 2019 11:45 pm
You can get the 7 pin dedicated kit fairly cheap, i got the 13 pin kit for red then turned on in ids and then fed it through etc.
Pf jones give you the full kit with fitting kit and instructions which actually was handy because the kit doesn't look that straight forward which is actually quite hard for us engineering types to get our heads around :x
Custom plugs in under the passenger plastic foot tray step.
Mk7 either the 2 passenger inner chassis leg at the front or there's a connector near the back I think?
But someone who's fitted the mk7 1 will be able to correct me in sure.
I fitted the 7 way bypass relay to snowflake, 10 quid or so :lol: cheap at twice that 8)
07 350 170ps
Ids map here
loot
Postby Airthies » Tue Jun 25, 2019 11:59 pm
Yea fitted a bypass relay to the big Guinea pig before symple an cheep, but was thinking if I'm going this far might as well do it properly to work with the parking sensors
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Airthies » Wed Jun 26, 2019 12:23 am
Actually lootee old boy...
Is there anything in the kit other than wiring and plugs?
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Wed Jun 26, 2019 7:40 am
Trailer tow module which is probably can bus.
Tbh my 13 pin kit was 2 boxes and weighed a fair bit, a lot of wiring and connectors, 130 quid though. Done once and done right, I normally think like you but in this case I just paid the ferryman. :wink:
07 350 170ps
Ids map here
loot
Postby Sandtoyz » Sun Nov 10, 2019 9:08 am
Hi All,
I'm in a similar situation as O.P.
Except, my van (08/2008) came with trailer wiring installed the lazy way, taken from rear lamps only.
So when tow hitch is on (and trailer), and reverse selected, the park assist just continuously goes off.
I'm currently sourcing an interface relay kit (on its way).
I do not have any factory installed trailer wiring, there is nothing in the footwells, etc.
Can someone clarify what the pin 4 'Trailer Detect' Does, or is wired to (image from BEMM).
Would this be a +12v or 0v trigger to the BCU to determine a trailer is connected.
I have an trailer connector that has a reed switch in the flap, could this be used back to this Pin 4?
Regards,
Dion from South Australia
2008 2.4L RWD 6-speed 140 350 LWB High Roof.
2005 2.4L RWD 6-speed 135 350 LWB High Roof.
Sandtoyz
Postby Airthies » Sun Nov 10, 2019 12:03 pm
Switches in the trailer sockets are usually for swapping fog lights from rear of van to trailer so the fog lights on the van do not reflect on the trailer while driving though I'm not sure what your plugs are like in Australia compared to the UK?
Would need to look at a wiring diagram to try and see what the trailer detect sense line is connected into to work out if it's a directed feed or a can signal.
My guess is that is looking for a return feed from the trailer tow module
Sent from my A55ho11 using Crapatalk
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Sandtoyz » Sun Nov 10, 2019 2:14 pm
Yeah, that's what I've gathered from reading on here.
I would expect it has to do something similar to disable the PAM.
My next option would be to put a relay in, operated from the socket switch, that drops off power to the rears sensors.
From what i can tell the sensor loom has 6 wires, so I suspect +12v, 0v and four return signals for each sensor.
Maybe someone can share the wiring diagram for the park sensors to PAM.
Australian trailers are(were) typically 7pin either flat or round, with no separate left/right clearance markers.
I've got a flat plug, with an electric trailer brake controller installed (pin 5 goes to the electric brakes).
Sandtoyz
Postby Sandtoyz » Sun Nov 10, 2019 2:17 pm
I also just noticed this may be in the wrong thread area...
I'd done a bit of forum keyword searches to find this particular post, and replied.
Sandtoyz
Postby Airthies » Mon Nov 11, 2019 12:25 am
Sandtoyz wrote:I also just noticed this may be in the wrong thread area...
What are you suggesting?
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Mon Nov 11, 2019 9:13 am
I've moved the thread from somewhere to here.
07 350 170ps
Ids map here
loot
Postby Airthies » Mon Nov 11, 2019 9:30 am
loot wrote:I've moved the thread from somewhere to here.
Why thank you. I never felt a thing
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Mon Nov 11, 2019 10:19 am
:lol: not sure what happened it may have already been played with as I know you would have put it in the right place when you wrote it.
Best say nothing and hope nobody notices :oops: :lol:
07 350 170ps
Ids map here
loot
