Hi
I'm having trouble starting a transit Mk7 2.4 100ps rwd minibis once started runs fine but just a pain to start it's done 350k km no lights on dash and don't want garages guessing what it is costing me money.
Any ideas please ?
Thanks.
jaystraveldirect wrote:Hi
Any ideas please ? Thanks.
knobby1 wrote:jaystraveldirect wrote:Hi
Does it play up when the engine is cold or all the time whether hot or cold..?? Air leaks at the fuel filter/filter head/leakback pipes are a common issue. This allows the fuel to drain back to the tank and it takes time to drag it back up when starting again. Has the fuel filter been changed recently..??
jaystraveldirect wrote:It does it whether the vehicle ir warm or cold seems harder to start when warm for example if I refuel it off for 5 mins its terrible put a new genuine fuel filter on it yesterday as indicator on fuel filter housing was on red hoping I'd solved it but it was still the same, injectors are prety loud till it warms up as well.
knobby1 wrote:jaystraveldirect wrote:It does it whether the vehicle ir warm or cold seems harder to start when warm for example if I refuel it off for 5 mins its terrible put a new genuine fuel filter on it yesterday as indicator on fuel filter housing was on red hoping I'd solved it but it was still the same, injectors are prety loud till it warms up as well.
Sounds like a candidate for a good old fashioned set of learns may help. How long since the last set of learns were done..??
jaystraveldirect wrote:knobby1 wrote:jaystraveldirect wrote:It does it whether the vehicle ir warm or cold seems harder to start when warm for example if I refuel it off for 5 mins its terrible put a new genuine fuel filter on it yesterday as indicator on fuel filter housing was on red hoping I'd solved it but it was still the same, injectors are prety loud till it warms up as well.
What is a learn ? Is it done via dignostic tool ? Thanks
