Where's the battery gone!!
Postby spondootre » Tue Nov 22, 2005 7:10 pm
Hi all,
OK so it's my first post and I will probably look like a bit of a fool by asking this question but........
Where is the battery on my Transit Jumbo?? It certainly aint under the bonnet!! There are just terminals for jump starting if needbe but how do I get to the actual battery??
Sorry if this is a no brainer!!
Malc
spondootre
Postby madmark » Tue Nov 22, 2005 7:18 pm
under your drivers seat mate! :D welcome by the way!
Postby spondootre » Tue Nov 22, 2005 7:33 pm
LOL, thanks!! I've been sitting on it all the time!!
Malc
spondootre
Postby Nighthawk » Tue Nov 22, 2005 9:36 pm
spondootre wrote:LOL, thanks!! I've been sitting on it all the time!!
Malc
Makes you feel safe to know your sitting on a hydrogen bomb dont it :lol:
Nighthawk
Postby FredTransit » Wed Nov 23, 2005 10:32 am
ya beat me to it! Who at Ford had that bright idea I wonder?
FredTransit
Mk2 Trannyist
Postby Nighthawk » Wed Nov 23, 2005 10:33 pm
Merc had had the battery there for years on their small vans, so it seemed like a good place to stick it.
The idea is that the battery is protected from the extremes of temperature change. The interior temps are warmer and cooler at the extremes of operating conditions giving better battery performance and charging.........they say :roll:
Nighthawk
Postby Valsheda » Wed Nov 23, 2005 11:56 pm
Nighthawk wrote:
The idea is that the battery is protected from the extremes of temperature change:roll:
BUT IF YOU HAVE HAD A WICKED CURRY BEFORE DRIVING , THIS MAY HAVE A SERIOUS REACTION HAVING A BATTERY UNDER YER SEAT :shock:
Valsheda
Top Tourneo Owner
Postby Nighthawk » Thu Nov 24, 2005 12:30 am
I'd be more worried about the reaction affecting the seat cover.....they can be a sod to get clean :lol:
Nighthawk
Postby trannytech » Fri Nov 25, 2005 12:09 am
think thats why they have a fuse in the earth lead so they dont blow up and take part of you with them
trannytech
Postby Valsheda » Fri Nov 25, 2005 12:16 am
STILL A WORRYING THOUGHT :lol: BUT I GUESS IF ITS NOT SAFE THEY WOULDNT PUT IT THERE , BUT WHY NOT KEEP THE BATTERY UNDER THE BONNET WHERE IT SHOULD BE , WHAT IF YOU NEED A JUMP START WITH THE OL LEADS , GOT TO BE EASIER LIFTING THE BONNET TO GET TO THE BATTERY :?
Valsheda
Top Tourneo Owner
Postby MrMPuk » Fri Nov 25, 2005 4:38 am
There are still connections to jump start it under the bonnet!
Postby Nighthawk » Fri Nov 25, 2005 10:26 pm
Valsheda wrote:STILL A WORRYING THOUGHT :lol: BUT I GUESS IF ITS NOT SAFE THEY WOULDNT PUT IT THERE , BUT WHY NOT KEEP THE BATTERY UNDER THE BONNET WHERE IT SHOULD BE , WHAT IF YOU NEED A JUMP START WITH THE OL LEADS , GOT TO BE EASIER LIFTING THE BONNET TO GET TO THE BATTERY :?
Have you ever tried to lift the bonnet of a Current transit which has seen less than perfect upkeep?
You can't get the key all the way into the bonnet lock because the grille panel has jumped out of it's catches at the top, so once you've refitted the grille and started to lift the bonnet, you find that the hinges have siezed and as you lift the bonnet it digs in to the cowle panel and causes damage to the panel and the bonnet.
The fuse in the earth lead is there in case of a dead short and will prevent the battery exploding.
Nighthawk
Postby Valsheda » Fri Nov 25, 2005 11:56 pm
NO I HAVENT OPENED UP A NEW SHAPE BONNET , BY THE SOUNDS OF IT ITS A NIGHTMARE ON A NEGLECTED VAN ,
DID I READ CORRECTLY THAT YOU NEED A KEY TO OPEN THE BONNET :?
Valsheda
Top Tourneo Owner
Postby Luke » Sat Nov 26, 2005 12:00 am
Valsheda wrote:DID I READ CORRECTLY THAT YOU NEED A KEY TO OPEN THE BONNET :?
yeah mate!! :D i had a mk6 pickup took me ages to find the bonnet release catch!!! :lol:
Postby Valsheda » Sat Nov 26, 2005 12:05 am
:lol: I CAN IMAGINE , HOW DID YOU FIND OUT YOU NEEDED A KEY :lol:
Valsheda
Top Tourneo Owner
