Idiots guide to IDS
Re: Idiots guide to IDS
Postby loot » Tue Oct 08, 2019 10:42 am
It'll change the revs but nothing else in aware of. Cruise switches off with clutch pressed but will still function the same.
Front and rear axles need to match don't they? You'll be burning against each other I would think?
07 350 170ps
Ids map here
loot
Postby Airthies » Tue Oct 08, 2019 11:12 am
loot wrote:Front and rear axles need to match don't they? You'll be burning against each other I would think?
Yes hence why in changing rear ratio from 3.58 to 3.73
But depending on the system some have a higher (lead) ratio at the front for cornering turning circle reasons.
Sent from my A55ho11 using Crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Cider Andy » Tue Oct 08, 2019 3:57 pm
Airthies wrote:One thing I was trying to do but couldn't was increase the tyre diameter, but even going through all the engineering codes I've found there's nothing, but wondering if a change in diff ratio would be too big a jump to correct the differences between diameters and Speedo. Need to get my math's head on
I found it in the 60274 option. There was a tyre size thing but there was also a tyre circumference thing. The tyres on the particular van weren't listed so I set it to User Size (or whatever). I calculated the circumference and found a value in the drop down list that was within about 2mm of my calculation, so went for that.
Drink moderately, eat healthily, exercise regularly, die anyway.
Cider Andy
Postby loot » Tue Oct 08, 2019 4:12 pm
I wonder though will the biggest option be the standard 16s at 2205 or whatever?
I had 255 55 18 on my mk7 and they were 9mm larger diameter but close enough 8)
07 350 170ps
Ids map here
loot
Postby Cider Andy » Tue Oct 08, 2019 4:29 pm
loot wrote:I wonder though will the biggest option be the standard 16s at 2205 or whatever?
2317.5mm rolling circumference, I reckon.....
Cider Andy
Postby Airthies » Tue Oct 08, 2019 4:49 pm
I'm running 225/75R16 with a rolling circ of 2337 or dia of 774
STD 16" for this van is 215/75 @ 2289 & 729
So haven't found any settings close to what I need.
Here's a list of other codes to help bollox your van electronics in funky ways
http://ford-vcm-2.blogspot.com/2017/04/ ... o.html?m=1
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Cider Andy » Tue Oct 08, 2019 5:22 pm
Airthies wrote:...rolling circ of 2337...
What numbers have you got in the drop down list?
Cider Andy
Postby Airthies » Tue Oct 08, 2019 5:31 pm
Not that much can't remember off top of my head but must be same as everyone else, think it's 22 something
oh and a typo on the dia it is 744 not 774
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Tue Oct 08, 2019 5:55 pm
The only 2 useful options I found were engineering mode and rcm mode.
The rest I didn't find much response to and any I did I didn't know what I was doing so stayed away from the big red button as it were. :lol:
I would have liked to done a new vehicle configuration that allowed me to write a 140ps map over the 130ps map. I'll have to do it manually though, just need to wait until someone is passing in a sport van :P beep beep loot.
Anyway did you solve the speedo conundrum?
07 350 170ps
Ids map here
loot
Postby Airthies » Tue Oct 08, 2019 7:36 pm
loot wrote:The only 2 useful options I found were engineering mode and rcm mode.
I would have liked to done a new vehicle configuration that allowed me to write a 140ps map over the 130ps map. I'll have to do it manually though, just need to wait until someone is passing in a sport van beep beep loot.
Nah it can wait, I need to plug in and reactivate RCL tonight,(and that's all) as last night while buggering about trying things I turned it off then forgot to turn it back on again so it's been say open over night and today again by the time I finished last night I couldn't be arsed plugging back in as it was nearly morning already.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Kev1000s » Fri Dec 13, 2019 8:30 am
Hi,
Looking at buying a vcm2 can any one point point me in direction of a fully working china special
Regards Kev
Ford FDS 2000
52 plate , Smiley 150lwb ,Td,Ex police :)
1996 Smiley 100 ,Td-Intercooled , lowered 50mm,mk6 wheels,lsd 4.11..
Kev1000s
Postby loot » Fri Dec 13, 2019 9:15 am
Kev have you tried modified elm327 and forscan. It does most things and under 20 quid 8)
07 350 170ps
Ids map here
loot
Postby Kev1000s » Fri Dec 13, 2019 9:42 am
Thanks for reply loot , can it do pcm update etc, ?
Ford FDS 2000
Kev1000s
Postby loot » Fri Dec 13, 2019 11:40 am
In not sure about pcm update.
It can do everything else though. You only use pcm update once generally but if your van is newer than 2011 eg then it isn't really needed.
If you are computer savvy and plan on making money on other ppls vans including pcm updates etc then ids is a good investment, if you plan on tinkering with your own van then forscan is quick, cheap and easy.
I'm any case you want ids vcm sp177-c1
07 350 170ps
Ids map here
loot
Postby Kev1000s » Fri Dec 13, 2019 11:48 am
Cheers loot, going to try get vcm2 , the model you say, seems to be out of stock..?
Regards Kev
Ford FDS 2000
Kev1000s
