Ford transit connect 1.5 TDCI 2017
Postby Enver » Sun Apr 21, 2019 3:19 pm
Hi,
I have a Ford Transit Connect 1.5 tdci from 2017.
The timing belt had snapped, and we changed the exhaust and intake valves.
Now the car starts fine and iddels fine, but when you drive about 100 meter, we get a fault code P2279 intake air system leak.
We cant really find the leak. At iddle 800rpm the maf sensor measures 8,5 grams pr second, and it should be around 10,5 grams pr second.
Will a leak in the valves cause this fault code? Any ideas what i should look after?
Thanks in advance!
Enver
Re: Ford transit connect 1.5 TDCI 2017
Postby p2thed » Sat Apr 27, 2019 12:12 am
Recheck timing,timing out by one tooth can set that code.
p2thed
Postby toni_18674 » Wed Oct 23, 2019 1:30 pm
Hi i have the same issue,how did you solve it please?
thanks
toni_18674
Postby mondeyo » Sun Dec 22, 2019 6:08 pm
Hi.you have camshaft problem.camshaft loops are turn away,my case 4 of those.watch the 1st and 3rd.
mondeyo
Postby Oskar81 » Tue Feb 09, 2021 10:20 pm
Hello i have this same troublecode P2259 in my car, the cambelt
Snapped, and we replaced it and also the valves and rockerarms,
The timing is good have checked it 2 times, is it possible that the
Camshaft is the problem?
Regards Óskar
Oskar81
Postby GringoCarService » Mon Mar 15, 2021 9:41 am
HI. Same problem with my 1.5 tdci 2017, have you all solved problem with the new one camshaft?? Thank you
GringoCarService
Postby Jonny88 » Thu Feb 10, 2022 3:32 am
Hi all
I have the same problem. However it can drive for 20 miles without coming on. Once the eml comes on it throws it into limp home. I have checked all seals and pipes hoses ect. Timeing on mine is perfect however new rockers tappets old camshaft. It idle fine and revs up OK. I feel a slight flat spot when it's boosting it would be great to know if you guys fixed the problem with a new camshaft?
Jonny88
