00353theking wrote:No just the end at the manifold
Sent from my SM-G965F using Tapatalk
Altransit wrote: I simply disconnected the control rod, and cable tied the butterfly on the air intake, in the wide open position
No, Heaven forbid...Tony-1976 wrote:Hi Guys,
im lost a little!!
do I need to find a metal ball which will fit into the egr metal pipe?
Tony-1976 wrote:I will attach some pics so you guys can see what I mean. A pipe has been cut off and blanked off with a bit could this be the famous egr blanking off?! If so the bolt is loose as anything I will put a jubilee clip on it and keep it in place.
wojciech wrote:But: blanking EGR is not legal and in this method (with cuted pipe) you can immediately see that EGR is blank (doesn't work).
