Mk7 transit won't go into gear
Re: Mk7 transit won't go into gear
Postby andz327 » Sun Jun 12, 2016 7:36 pm
Neil wrote:
New transit owner wrote:Hi all thanks in advance for advice info I have a mk7 transit drove
Spot till I turned engine off now won't go into gear when engine running
Will go into gear with engine off and will drive till I have to change gears
Any advice would be great checked for leaks in fluid but haven't a clue
On what to do local garage say clutch but a new one got fitted s year ago so
Thanks again
the gear change has rods or cables and had those changed was good as new again
So it was driving perfect and switched it off and came out in the morning and the rods and cables knackered up over night
andz327
Postby andz327 » Mon Jun 13, 2016 2:17 pm
Any joy with the beast???
andz327
Postby New transit owner » Wed Jun 15, 2016 10:44 pm
Good news people it was the clutch worn down by the last monkey
Leaving a tool in it according to the mechanic who took it apart so the
Beast is back thanks for all the advice grafefull as always
New transit owner
Postby Inelectron » Fri Jan 03, 2020 12:21 pm
Thanks again
Hello, i have the same problem with my 2010 mk7 transit. Sorry to say i havent found out the problem too, all i do know is that ive had new gear box just fitted and it only happened after that :| The simptons from the van where as follows: When putting the clutch down the engine was making a strange sound but once down or up it stopped, gears would easily go in if the engine was off, sometimes i could start the van and the gears would work fine but other times it was impossilbe to get in any gear with reaptedly turning the van back off and on again untill after maybe a 40 seconds it would work again. Clutch and gear box feel great once working so very confused, tuck the van back to the garage and they changed the gear link cabbles again, plus bled the clutch slave cylinder as that was my guess. Once back it felt better but two days later still the same result, will be taking it back again so any news i get ill update.
Inelectron
Postby knobby1 » Sun Jan 05, 2020 8:58 pm
Inelectron wrote:Hello, i have the same problem with my 2010 mk7 transit. Sorry to say i havent found out the problem too, all i do know is that ive had new gear box just fitted and it only happened after that :| The simptons from the van where as follows: When putting the clutch down the engine was making a strange sound but once down or up it stopped, gears would easily go in if the engine was off, sometimes i could start the van and the gears would work fine but other times it was impossilbe to get in any gear with reaptedly turning the van back off and on again untill after maybe a 40 seconds it would work again. Clutch and gear box feel great once working so very confused, tuck the van back to the garage and they changed the gear link cabbles again, plus bled the clutch slave cylinder as that was my guess. Once back it felt better but two days later still the same result, will be taking it back again so any news i get ill update.
Thread is 4 years old now...best to start a new one with your issue...:
Is yours FWD or RWD..??
Have you had a new clutch when the box was replaced..??
Postby andz327 » Wed Jan 08, 2020 9:39 pm
Whats happening ...... Sorted ...
not sorted......???????????
ANDZ
andz327
Postby bambi mk 1 » Wed Jan 08, 2020 10:21 pm
andz327 wrote:Whats happening ...... Sorted ...
ANDZ
Knobby chased the poor man away :mrgreen: :wink: :P
bambi mk 1
Postby knobby1 » Thu Jan 09, 2020 3:33 am
ANDZ
Yep....and I wasn't even trying..!! :mrgreen:
Postby andz327 » Wed Jan 15, 2020 12:00 am
ANDZ
Lord knobster you need to stop asking people to play with yer billabong
ANDZ
andz327
Postby knobby1 » Wed Jan 15, 2020 12:53 am
andz327 wrote:Lord knobster you need to stop asking people to play with yer billabong
ANDZ
A "billabong" is Aboriginal for "waterhole"....WTF..?? :mrgreen: :shock:
Postby andz327 » Wed Jan 15, 2020 1:08 am
Exactly lol
Sent from my SM-G975F using Tapatalk
andz327
