tacho/speedo signal
tacho/speedo signal
Postby snoopaloopa » Thu Jul 12, 2007 6:51 pm
I have searched but couldn't seem to find the answer, so which wire can i use from the rear of the instruments to pick up a tacho signal for my satnav? unfortunatly i found it in my '51 plate but didn't write it down :(
its for a '55 2.4 if it makes any difference :?:
thanks guys 8)
snoopaloopa
Postby MrMPuk » Thu Jul 12, 2007 6:59 pm
Postby snoopaloopa » Thu Jul 12, 2007 7:59 pm
ok, so maybe i'm a bit stupid :D but what the hell does that mean :?: :D
i need a bit of context i think because that means absolutly nothing :cry:
snoopaloopa
Postby MrMPuk » Thu Jul 12, 2007 10:29 pm
What is it you don't understand?
Postby snoopaloopa » Thu Jul 12, 2007 11:53 pm
is it the white wire or the vss thing :?:
snoopaloopa
Postby MrMPuk » Fri Jul 13, 2007 12:04 am
Listen to Nighthawk
Postby snoopaloopa » Fri Jul 13, 2007 7:13 am
exactly :? without context it means nothing :roll:
snoopaloopa
Postby MrMPuk » Fri Jul 13, 2007 10:00 am
snoopaloopa wrote:exactly :? without context it means nothing :roll:
:? Do you still not have a clue?
Postby snoopaloopa » Fri Jul 13, 2007 8:18 pm
not a scooby :( I know its a plug but where is it because i've had a look today and i can't see it, the signal comes off my gearbox then goes to the ecu on a white/blue and violet/grey, can i just pick it up off of one of these or is there somewhere easier inside the cabin :?: or am i just being slightly retarded :roll: :wink: :D
snoopaloopa
Postby ME » Fri Jul 13, 2007 10:45 pm
When i had a Tachograph Fitted to my (55 lwb hiroof 135 6 speed silver blue thats for Mr Puk) They could not get a speed pulse off of the radio and ended up getting one from the loom on the bulkhead on the Ns
ME
Postby snoopaloopa » Fri Jul 13, 2007 11:03 pm
thats what i think i might have to do, pick it up before it goes into the ecu and gets a scrambled into transit speak :D
snoopaloopa
Postby snoopaloopa » Sat Jul 14, 2007 2:45 pm
pin 13 in the engine bay connector in front of the fusebox, sorted 8)
snoopaloopa
