Emily's thread mk1 landliner (lot of pics)
Postby gemini » Tue Jun 26, 2007 11:07 pm
2nd one from the left is the smallest gap
gemini
Postby Luke » Tue Jun 26, 2007 11:11 pm
i'd be happy with the plugs - at least they show no major engine problems :D
while there out - try a compression test - it'll give you good info on the engine :D
Postby MarkM » Tue Jun 26, 2007 11:15 pm
gemini wrote:2nd one from the left is the smallest gap
Yes you are right as I looked again at the picture, probably the only correctly gapped one.
MarkM
Postby rottie_007 » Wed Jun 27, 2007 6:23 pm
here are some pics of the ro im trying to eradicate from behind the steering box..
I would have done more today but the weathers been awful and by the end of the day I had well and truly had enough
heres the chassis rail
The major hardship was getting to it to be honest, there are a couple of small bits I can see under that arch I will do at the same time ust to waterproof the cab a bit...
The rot soon cuts back to bright metal though so im quite pleased about that, god knows how long the top of the rail had been gone though, i hoovered half a dyson full of crap out of it...
maybe this is why shes had 11 owners in the last couple of years.
my upholsterer reckons the custom transit seats are salvagable so thats another bit of good news
1979 mk2 pre facelift CI campervan " Bessie Brown "
1994 Pug 405 est " George "
1998 pug 106 "Mildred"
rottie_007
READY FOR RETEST!!!
Postby rottie_007 » Thu Jun 28, 2007 9:12 pm
Fingers crossed for tomorrow...
finished the welding tonight...
so will book retest tomorrow and get her two tyres done at the same time
(spare no good so new ones on front and best of fronts to spare I think) :shock:
rottie_007
Postby rottie_007 » Fri Jun 29, 2007 5:46 pm
mot achieved...
least I can use her and move her about legally now
on way back from MOT strange noise began appearing at tickover...
is there a spigot bush or bronze on these vans?
no noise at higher rpms but at tickover its horrendous.. and intermittent
rottie_007
Emily Update....
Postby rottie_007 » Thu Jul 12, 2007 8:19 pm
after weeks of ownership it occured to me the engine was stupidly quiet for OHV and had an absolutely awful tickover at least 1 or 2 cylinders not firing at least
so I bought myself some nice new feeler gauges and a haynes manual off of ebay and set about re-setting the clearances of the valves..
first problem was working out the numbering of the valves, only after flicking back and forth through the manual till it fel to bits almost did I realise it said in BOLD under the diagram FRONT OF ENGINE
so ran them through nipped the covers back on put the plugs back in (looked very lean compared to last strip so might have to richen the carb up a bit)
and started her up..
took a little bit of winding to get her to go but when she went she settled into the smoothest tickover I had ever seen, I could almost have sat a glass of water on top of the engine I think without it spilling...
have got a tick from one of the back ones but I think thats my fault from misjudging when the other two were open (as it says in the manual) but the main thing is she is ticking over smoothly on all four now
inside the engine looked very clean with no signs of the black goop you often see in older cars so reckon the mileage may be correct
if anyone has an easy way of tappeting then please let me know !!
:roll:
rottie_007
Postby rottie_007 » Thu Jul 12, 2007 8:20 pm
rottie_007 wrote:mot achieved...
traced this to blocked breather pipe , dont know how it made the racket it did but its all quiet now
rottie_007
