Mk2 pinto to early di conversion
Postby Luke » Fri Jul 13, 2007 6:29 pm
Retrohowla wrote:Oh and also, my gearbox is ally and has a flange coupling to connect to the prop leading me to believe its a mt75 correct?
correct - best box to have :D
Postby Retrohowla » Fri Jul 13, 2007 6:33 pm
Good :D so i was right when i stood there and told said vegetable it was an mt75 and he insisted it wasnt as i didnt have to lift a lever under the gear knob to get it into reverse
i asked him how practicle a lever would be on a two foot gearsick with a dog leg and he just shrugged and told me it coulnt be a my75!!!!!!! :shock:
I think i might buy him an electric wheelchair and dribble bib for xmas
If you own a transit, learn to weld
Retrohowla
Postby Retrohowla » Fri Jul 13, 2007 9:26 pm
Cleaned, painted new belts, bearings and seals as required now just waiting on that cranl seal to rebuild :D
Retrohowla
Postby Retrohowla » Sat Jul 14, 2007 8:02 pm
Ok so was about to rip out old smokey when i found this...............
and this........
and this..........
Oh dear, dont look like its gonna be a quick fix :cry: :cry: :cry: :cry: :cry:
Retrohowla
Postby FredTransit » Sat Jul 14, 2007 10:29 pm
Bugger! That's the problem when you start working, finding stuff like that. Still got to be done, and you might as well find out now as at the MOT.
FredTransit
Mk2 Trannyist
Postby Retrohowla » Sun Jul 15, 2007 10:47 pm
Right as i am waiting on materials for the chassis repairs i though i would offer up the motor for a 'dry fit'
Seems to fit ok and nothing seems to be playing me up...............yet but any hints and tips before i remove again to tidy the engine bay and cut out the floor around the gearbox???????
Retrohowla
Postby Retrohowla » Thu Jul 19, 2007 10:04 pm
Right a little update, the motor is in and running! :D but the airbox wont fit now :( so might have to graft on a k&n from the pinto :?
So the return to the tank is done with no probs and it starts, charges and all lights on dash go out etc
throttle is on, clutch and speedo still to do, temp hole in floor for gearstick, (think i buggered up somewhere when cutting mk4 floor out) prop is being lengthend as i speak so just got to mod the rear mounts for it to be properly bolted in
cant think what else i have done but been flat out every chance i get, oh old crossmember out and new one ready to weld in :D
Retrohowla
Postby FredTransit » Thu Jul 19, 2007 10:08 pm
Haven't you been busy? I can't think why the air box doesn't fit.
FredTransit
Mk2 Trannyist
Postby Retrohowla » Thu Jul 19, 2007 10:10 pm
Its the round 'sit on top' style and fouls on the bulkhead
if i had the later style that lives down the side it wouldnt be a problem i guess?
Retrohowla
Postby Luke » Thu Jul 19, 2007 10:12 pm
well done mate - teld you it was easy :lol:
i once had 3 mk1s all Di'd and parked next to each other and each one was in a different postion :shock: - my bus wouldnt fit the mk4 air box on so i used the early steel one with the back edge slightly battered in :lol:
Postby FredTransit » Thu Jul 19, 2007 10:13 pm
that's the stule that is fitted to the original, we have two facoty Mk2 DIs, not the original engines any more but the air filters must have been reansferred on to the engines.
FredTransit
Mk2 Trannyist
Postby Retrohowla » Thu Jul 19, 2007 10:13 pm
Oh do you think 16 gauge is a little thick to make a new front panel with?
Just got a big offcut from making the x-member and on a budget!
Retrohowla
Postby FredTransit » Thu Jul 19, 2007 10:15 pm
You can't go too thick for cross members and chassis!
FredTransit
Mk2 Trannyist
Postby Retrohowla » Thu Jul 19, 2007 10:15 pm
stule?????
sorry not being funny but dont understand last post properly, whats a stule? and what is reansferred?
Retrohowla
Postby Retrohowla » Thu Jul 19, 2007 10:17 pm
Yeah thats why i am using 16 gauge for the x-member but its the front pannel that holds the headlights etc that i am on about now as its been cut out by some monkey so i have nothing to mount the lights, rad etc too
Retrohowla
Return to Mk 1 & 2
