Brake Disc Torque Bolts
Postby seikokid » Sun Apr 19, 2020 8:41 pm
I know these are meant to be replaced when removed and fitting new discs front and rear, but in the present given climate is it’s really a necessity? - can i reuse? - or am i looking for trouble ?
seikokid
Re: Brake Disc Torque Bolts
Postby Punto443 » Sun Apr 19, 2020 9:56 pm
Threadlock
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby seikokid » Sun Apr 19, 2020 9:58 pm
ah! are they not stretch bolts like used in engines and have 1 use lifespan ?
seikokid
Postby S60r » Mon Apr 20, 2020 8:45 am
I have changed many disks over the years but never on the Custom (yet). I have always reused the bolts if they are in good condition of course.....
You have made me worry about that now!
I personally would go for it and then recheck the torque after 4-500 miles to be sure. It only requires slipping a wheel off to check..... but that’s just me.... if it’s similar to steel erecting then yes.... bolts are one use only. Please post back if you find this definitely to be the case as I will never reuse bolts again!
I wouldn’t be using thread lock on a serviceable part though! You’ll be swearing if you keep the van long enough to have another set!!
S60r
Postby seikokid » Mon Apr 20, 2020 9:17 pm
thanks for the help, was at ford today for an emergency repair and asked the question - thread lock was the answer and not stretch bolts
it’s not a straight forward job changing all 4 discs on the custom. however when ford charge you £550 just for the pads and you have 2 vans i’ll spend all week doing it myself
seikokid
Postby S60r » Mon Apr 20, 2020 10:31 pm
seikokid wrote:thanks for the help, was at ford today for an emergency repair and asked the question - thread lock was the answer and not stretch bolts
wow! Quite right!
That is a mental price! How can they justify that?!
Hope it goes well Seiko.... post back to let us know how you get on as I'm sure it won't be the last time this question arises. (Given the cost of the pad replacement!)
S60r
Postby seikokid » Mon Apr 20, 2020 10:47 pm
it’s involved !
but found some issues and only done one side !
seikokid
Postby Punto443 » Mon Apr 20, 2020 11:46 pm
Looks about the same as a mk7.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby seikokid » Wed Apr 22, 2020 3:49 pm
So same issue both front discs inside, only centre of pad working
and both rear inside pads wearing down at an angle
all done now...
seikokid
Postby S60r » Thu Apr 23, 2020 7:55 am
top work! good money saving exercise too!
Odd that they weren't wearing evenly though?
S60r
Postby seikokid » Thu Apr 23, 2020 7:57 am
thanks, always do these repairs myself but this certainly has been the most challenging
Got the car to do next ! my
missis is fed up of me saying i have to replace the brakes ...
seikokid
Postby S60r » Thu Apr 23, 2020 10:20 am
Yes seiko..I know what you mean.
One good thing about this lockdown I suppose..... at least we get to do all those jobs we’ve been putting off for a while.
Saving yourself fortunes too. Nice one.
S60r
Postby Abbadon » Thu Jun 25, 2020 2:35 pm
Did you have much grief getting the 36mm nut undone?
Also, did the disc and hub come off the hub carrier ok?
Andy
Abbadon
Postby seikokid » Sun Jun 28, 2020 6:10 pm
Yes, i have a 1m breaker bar and had the wheels on the ground and in gear.
Good rattle gun can help with the unthreading as that’s boring and long
Once all the torque bolts were out a think i had to tap the inside of the disc with a small lump hammer and i seem to remember using a metal chisel at times.
seikokid
Postby Abbadon » Mon Jun 29, 2020 8:47 am
welll, here is a tail of two cities....
One side came apart fairly easily, hub nut yeilded to just my 3/4" breaker, and driveshaft knocked out with a lump hammer and alloy bar, but i think this is because of the root cause of the knocking that began last week - the disc was fractured down the middle of the cooling fins, and by the time i got it off the hub on the floor, it was in two pieces! I think when they changed the pads just before we bought it - they should have changed the discs too - and its been overheating on one side - so that side has got hot at some stage - maybe making it easier to remove??
Image20200628_165349 by Abbadon2001, on Flickr
Image20200628_165332 by Abbadon2001, on Flickr
The other side, was a total tw%$ to take apart. The van only has 40k miles, but the hub nut required much more persuading, 3/4" breaker bar, inside a scaffold pole and it broke free. But the driveshaft, would it come out, would it b@ll%c$s! After whacking seven shades out of my ally bar and the lump hammer, I set up an axle stand and a bigger lump of alloy and tried the sledge, still no joy. So I had to go get a large puller from my dads, and wind that on to it, which eventually with the help of impact breaker and pole finally got it out...
Image20200628_105224 by Abbadon2001, on Flickr
Image20200628_105218 by Abbadon2001, on Flickr
Abbadon
Return to Transit Custom
Users browsing this forum: noeljary
