Fault Code P0642
Fault Code P0642
Postby RichieC » Sun May 03, 2020 8:15 am
Good morning everyone,
I’m new to this forum but looking through the site there are so very knowledgeable members so I’m hoping you may be able to help.
I’m a mechanic and I’ve been looking into a fault on a transit this week.
2009 Mk7 2.4 140bhp
It came in with what sounds like diesel knock, we carried out a diagnostic check and the only fault code showing was P0642 Low Voltage Circuit A.
I have checked through live data and noticed that the rail pressure was showing 58000-61000 kph on idle but we had No Injector Correction Values Showing!
The work completed so far:
New PRV Valve
New Rail Sensor
New SCV Valve
Fuel learn procedure
New Batters X2
Check the loom for and charging or damage
Checked the fuse box in the engine bay for corrosion
The vehicle did run for 5-10 run up tests perfectly with all the live data showing and we thought the vehicle was complete and then came in yesterday to arrange collection with the customer and it was back to the original fault and diesel knock.
Any help would be appreciated as I feel it’s an electrical fault somewhere.
RichieC
Re: Fault Code P0642
Postby knobby1 » Sun May 03, 2020 9:13 pm
P0642 it is my apologies.
Postby bambi mk 1 » Sun May 03, 2020 9:17 pm
knobby1 wrote:P0462 is a faulty fuel tank level sensor or possibly the wiring to/from it..
Glasses Knobby :wink: :wink: :wink: :lol: P0642 the op posted
bambi mk 1
Postby knobby1 » Sun May 03, 2020 9:39 pm
bambi mk 1 wrote:Glasses Knobby :wink: :wink: :wink: :lol: P0642 the op posted
Oh dear...l'm bloody dyslexic now... :roll: :oops:
Postby heinkok4 » Fri Mar 04, 2022 7:03 pm
Hi Guys
Yesterday my van died on me and according to Forscan it is the same code - P0642 Sensor A voltage circuit low
My van is an old 2008 85 Hp. Did anyone found a solution to the problem? I have checked fuses and connectors, but no luck so far.
Any help or guidance would be appreciated
heinkok4
