Qldmts wrote:Ok thanks for that but today I found out the engine I have is not the same, it is a Duratorq V184 90PS (sticker on the timing chain cover) Looks exactly the same as the motor I have but this one is not common rail. I have the ECU for this engine but I also have another 115Hp engine that is no good and ECU and I am not sure which ECU goes with which,
Basically I don't care about the drop in power as the car is not used on the highway, I just want to get it going if I can using the 90Hp motor.
Can I put this engine in and its ECU once I know which one it is and make this go. It looks like the wiring loom in the car itself is the same and it is just the loom on the engine that plugs into the car loom and then swap out the ECU and maybe it will go.
If anyone has done swaps and they would be most likley going from a 90Hp up to something higher let me know what drama you had.
Qldmts wrote:Another thought would be to change the pump, injectors from the H9FA onto the 90hp as the engine is the same it seems, I am told there is just an oil gallery to unplug and place the pipe from the H9FA into it so the pump gets oiled. This also seems to easy as I would have thought cams may be different and the head might be but looking at both engines side by side they look the same except for the difference in the common rail and pump of course.
Qldmts wrote:I'll have to do some checking, if the injectors are different that would be the first dead giveaway, I was reading a post where someone had changed over a DOFA, I think it was, but it never told if he succeeded in the end. That was where I saw the comment about the oil hole under the pump.
Qldmts wrote:Yes but will the electronic injectors go into the head of the 90hp motor without fouling the pistons and if I change all the common rail stuff over will it run. Basically turning a 90hp into a common rail. Everything looks like it will bolt straight on. If this works then no ECU swapping etc is needed.
That the job for today to see if this can be done.
fumbduck wrote:How did this turn out in the end ?
But you can try it and let the rest of us know how you get onmistyv6 wrote:i to would like to know if you can fit mechanical injectors to a common rail head so i can use a mechanical fuel pump
