2012 2.2fwd Euro5 Problems please help
Postby Callum aspinall » Fri Jun 05, 2020 12:21 am
I’ve recently bought a new van for my business and I’ve had nothing but problems with it
Yesterday it broke down with no indications that anything has been wrong apart from it running a bit under powered which I expected to be a lazy injector or something
When it broke down I got the cog with the exclamation and the battery light
Once in a safe place it started again reeves to to 3-4 thousand then died again and hasn’t started since
I’ve had a friend scan this for me and the codes recorded are
P2539-00 low pressure fuel sensor circuit
P0101-00 mass or air flow circuit range/performance
P2291-00 injector control pressure to low engine cranking
P0113-00 intake air temp sensor 1 high input
U0120-00 lost communication with starter/ generator control module
The mechanic reckons it needs a new fuel pump but after reading a few forums on this these codes don’t show that but any help would be appreciated
Thank you
Callum aspinall
Re: 2012 2.2fwd Euro5 Problems please help
Postby Airthies » Fri Jun 05, 2020 7:03 am
Rare for the Mk7 fuel pump to go, (though not impossible) more likely something else.
Have you cleared codes then tried to start it and then see what codes return?
More likely SCV and PRV giving issues, you need to check cam and crank sync.
fuel pressure desired
and fuel pressure actual
On live data while cranking.
Sent from my A55ho11 using Crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Callum aspinall » Fri Jun 05, 2020 7:12 am
Yeah we cleared all codes and these came back still no start
Callum aspinall
Postby Airthies » Fri Jun 05, 2020 7:36 am
Check what I've mentioned and see what you get, then can go from there.
Have you replaced fuel filter?
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Callum aspinall » Fri Jun 05, 2020 3:08 pm
I’m gonna borrow the snap on scanner this weekend to try get some live data
Yes it’s had a new filter about 4 month ago on a service
Well they said it had when I bought it
Callum aspinall
Postby davyjcb » Fri Jun 05, 2020 4:11 pm
It's Euro 5 so it won't have conventional scv/prv as was on Euro 4
2 things I would be checking ,turn on ign until lit but don't try cranking then either listen for the pump in the tank or depress the shrader valve fitted in the fuel line between the filterhead and the high pressure pump to see if the low pressure pump in the tank is supplying fuel as the euro5 hp pump needs a certain amount of pressure in order to work.
96 escort 55 van gone
98 smiley mwb semi high gone
01 90/350 mwb semi high roof gone
05 135/350 lwb semi high roof gone
10 85/260 swb low roof leader gone
09 140/350 lwb semi high fwd
11 115/330 mwb semi high roof
davyjcb
Postby Callum aspinall » Fri Jun 05, 2020 10:34 pm
davyjcb wrote:It's Euro 5 so it won't have conventional scv/prv as was on Euro 4
Ok thanks I’ll try this in the morning
Callum aspinall
Postby Callum aspinall » Mon Jun 08, 2020 11:56 pm
Hi I’ve checked the lift pump and the schrader valve in the fuel line and I had nothing no fuel at all
I pulled diesel through with a vac hand pump and still nothing when I cranked then
Whilst vacuuming the fuel line I broke the leak off pipe at the push fit connection
Then I remembered that the old escorts used to have fuel cut off switch’s on them found the transit one and reset it
Now I have fuel pressure to the pump and the schrader valve
But it still won’t start but I don’t kno wit it is because the fuel is now pouring across the floor
Whilst trying to crank the van over the fuel cut off cut itself of a few times
Has anyone got any ideas????
Callum aspinall
Postby Callum aspinall » Tue Jun 09, 2020 5:41 pm
Has anyone ever had these problems???
Callum aspinall
Postby karl » Wed Jun 10, 2020 9:24 pm
they dont have a full cut off
does the electric pump work in the tank
can you activate it with diagnostics
low fuel pressure could also be injectors leaking back to much
karl
Tranny Lover!!!
Postby bambi mk 1 » Wed Jun 10, 2020 9:47 pm
karl wrote:they dont have a full cut off
You need an update on IDS ,euro 5 have an inertia switch in the glovebox,another school day eh :!:
bambi mk 1
Postby karl » Wed Jun 10, 2020 10:11 pm
another school day as always with you :lol: :lol:
i have never seen a fuel cut of in a glove box of the one i maintain
am sure a picture may be help me :?: eeh
karl
Tranny Lover!!!
Postby bambi mk 1 » Wed Jun 10, 2020 10:24 pm
Can you work this out or will I drop over and show you :mrgreen: viewtopic.php?f=5&t=132900&hilit=inertia+switch&c=1
bambi mk 1
Postby Callum aspinall » Thu Jun 11, 2020 10:48 am
So a bit of a update I’ve managed to get the thing started and driving
I do t know what it was but after resetting this switch and wiping the error codes it started and ran
But now there’s a bit of a problem On full throttle through all the gears it runs perfect but when your in traffic and keeping the Rev range low say 1500 to 3000 rpm plodding along at 30-40 the van runs very lumpy and jerky and starts to smoke really bad and smells of unburnt diesel until again you use full throttle then it clears
So basically if I thrash it with my foot to the floor it’s fine until I have to drive at a normal speed then it starts
Callum aspinall
Postby karl » Sun Jun 14, 2020 8:46 pm
Looked at a euro 5 tonight and yes their is a yellow fuel cut of switch :mrgreen:
karl
Tranny Lover!!!
