NEW BLOODY TRANSITS
NEW BLOODY TRANSITS
Postby eddie anderson » Tue Nov 22, 2005 7:22 pm
I have a fault on my 51 plate transit which causes it to cut out and die, give it ten mins it will burst into life then cut out again ten mins later only not to start untill it is at the garage and they tell me there is nowt wrong with it, its doing my nut in. I have a friend with a 54 plate which was doing the same but Ford fixed that with a new unit, I am at my wits end, it has cost me a grand already. Please help
EDDIE
eddie anderson
Postby dan@dsfplumbing » Tue Nov 22, 2005 7:41 pm
Don't worry mate. My brother's on his 2nd 05reg Vivaro and this one is crunching 3rd gear and has in termittent charging problems already !!
dan@dsfplumbing
Postby FredTransit » Tue Nov 22, 2005 8:02 pm
........best get yourself a classic mate, much easier and cheaper to repair!
FredTransit
Mk2 Trannyist
Postby Valsheda » Tue Nov 22, 2005 9:33 pm
IN ANOTHER TWENTY YEARS I WILL BE ABLE TO MAKE THAT STATEMENT FRED :lol: :lol:
Valsheda
Top Tourneo Owner
Postby FredTransit » Wed Nov 23, 2005 10:29 am
Valsheda wrote:IN ANOTHER TWENTY YEARS I WILL BE ABLE TO MAKE THAT STATEMENT FRED :lol: :lol:
You might be able to say that Val, but many, many others wont! Between the dodgy gearboxes, microchips that cost 100s, suspension being ripped off on kerbs and unexplained rot I doubt as many Mk4s or whatever will make it to classics. If, in a few years time the owner of a 6 year old van is faced with a bill for say £1000 for a selection of any of the above, the van is more likely to be scrapped than repaired. This happed with the Mk2 in the 80s. I am sure more perfectly repairable vans were sent to the scrappie than should have been, just because the owners couldn't be bothered and wanted a newer van. Even I have to admit the members of this board are the exception rather than the rule, we are prepared to do what it takes, or know somebody who can!
FredTransit
Mk2 Trannyist
Postby cad69 » Wed Nov 23, 2005 8:49 pm
Hi Fred
It was something I was pondering on. As the values depreciate, at a commercial decision, it becomes no longer sensible to repair but then if you factor in that there is no more depreciation and possibly appreciation and the earlier models are user workable the commercial decision to keep them becomes justified. Then there is the bond between the driver and his/her machine that no monetary value can decipher.
An analogy would seem to be that if a family labrador needed a vet bill of 200 quid and a new pup could be had for 150 why would you fix the old one?
Cheers Cad
cad69
Postby FredTransit » Thu Nov 24, 2005 9:59 am
cad69 wrote:Hi Fred
Cheers Cad
Getting a bit off topic here, BUT your analogy is brilliant. I was as upset loosing a van in an accident as I was to loose a dog. However on a purley business note I have never understood why people think it's more cost effective to to spend £3000 on another used van rather than £300 on welding or other work for the MOT. We all have to have road tax, it's the same for any transit, and as for insurance it's cheaper to insure and old van than a brand new one cos at a total loss the insurance company has a smaller payout.
FredTransit
Mk2 Trannyist
Postby rover » Thu Nov 24, 2005 10:49 am
I would suggest getting a 'diagnostic' test run on it and get the computer printout before shelling out on any parts, the ECU will be logging the fault if its anything major electrical.
If its not electrical then the options come down to fuel related problems.
rover
Postby Gunslinger » Sun Nov 27, 2005 12:09 pm
i would agree you have to get the printout first to see if it will guide you in the right direction, or you'll end up changing good parts at a considerable cost only to eliminate them as a problem, effective method but time consuming and expensive, from what you have said it sounds like something doesn't like getting warm, or you have something like a fuel starvation problem, i don't know with the newer transits but i have heard of some vehicles having a problem because the tank breather gets blocked and the pump then fails to suck fuel from the tank causing it to cut out, leaving it 10 minutes and the pressure drops enough to allow the pump to function correctly
Gunslinger
Postby Luke » Sun Nov 27, 2005 12:31 pm
Gunslinger wrote:to allow the pimp to function correctly
ImageEh?? :wink: :lol:
Postby rover » Sun Nov 27, 2005 1:09 pm
It must be the hat! You definatelt wont get a Pimp to function properly with the hat :shock:
rover
Postby MrMPuk » Sun Nov 27, 2005 2:13 pm
Postby Gunslinger » Sun Nov 27, 2005 2:38 pm
:| :roll: :twisted:
Gunslinger
Postby jay » Sun Nov 27, 2005 2:50 pm
that loks like next door!! :shock:
mk1 connect tourneo
jay
Postby stevew » Sun Nov 27, 2005 4:44 pm
LOL! :lol:
Yeah no self respecting pimp could fit his hair under that hat!
stevew
