Idiots guide to IDS
Re: Idiots guide to IDS
Postby ediesbra » Tue Jun 23, 2020 7:50 am
Okay buddy will give it a shot :) thanks pal
2009 Mk7 2.4TDCI Jumbo in Panther Black with air con, cruise control, auto headlamps, auto wipers and hill start assist.
Former -
1998 MK5 150LWB
2005 MK6 Welfare unit 115 350 LWB Hi Top
ediesbra
Postby ediesbra » Tue Jun 23, 2020 4:19 pm
Right I think we’re getting somewhere :) passenger side has -3.0 mv on brake light circuit when side lights are on, drivers side has +5-10mv which tells me I have a short somewhere. Wiring is a mess underneath. It does have button leds all down the side would this make a difference??
Former -
1998 MK5 150LWB
ediesbra
Postby Airthies » Tue Jun 23, 2020 8:03 pm
It depends how they're connected in.
Best I can suggest is run a dedicated earth from lights back to battery or at least make sure your earth points are good.
Whip the bulbs out and go for a drive check if it makes a difference. Especially the RH side.
Now of course you'll be driving on your section of private road or track as I would hate to be seen to suggest anything illegal.
Sent from my A55ho11 using Crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby ediesbra » Tue Jun 23, 2020 11:19 pm
Haha of course, I’m off to my private runway! Well I ran a new earth point with way bigger cable, it got the mv reading down but not much. If I disconnect the earth completely from the light the side lights stay on anyway!!! If I take the bulb out and do a reading the mv reading goes above 100mv. I think I’m going to rewrite my rear lights completely but the thing is I don’t know where the issue is :(
Former -
1998 MK5 150LWB
ediesbra
Postby davyjcb » Wed Jun 24, 2020 6:24 pm
Have you got a trailer socket, they have been known to short where they go through the tin mounting bracket also if it has a smart relay for a trailer that has a draw
96 escort 55 van gone
98 smiley mwb semi high gone
01 90/350 mwb semi high roof gone
05 135/350 lwb semi high roof gone
10 85/260 swb low roof leader gone
09 140/350 lwb semi high fwd
11 115/330 mwb semi high roof
davyjcb
Postby ediesbra » Thu Jun 25, 2020 4:07 pm
No trailer socket bud. But the wiring under the van is a bit of a mess so think I’m gonna rewire it and go from there.
Former -
1998 MK5 150LWB
ediesbra
Postby spudmab » Sat Jun 27, 2020 11:13 am
Hi everybody it might have been covered but im a bit lost.
I have got this message when i plug into my van, not sure how to sort it
Any ideasImage
Sent from my SM-G960F using Tapatalk
spudmab
Postby Airthies » Sat Jun 27, 2020 2:35 pm
spudmab wrote:Hi everybody it might have been covered but im a bit lost.
Any ideasImage
What van you plugging into and what version of IDS are you running?
V86+patch
V86.04
X-Prog
C81
Airthies
Postby spudmab » Sat Jun 27, 2020 6:34 pm
Its v86 i think, and my van is a mk6 2.4 crewcab X tipper. Image
spudmab
Postby spudmab » Mon Jun 29, 2020 9:32 pm
I have now reinstalled ids, i used the v86 and v86.4 from loot.
I run the installation through, i done a vcm reset and let that run through, and i am still getting the same message if i try to start a new session.
Any thoughts or ideas as im confused
spudmab
Postby loot » Mon Jun 29, 2020 9:38 pm
What year is your van mate? Pre 04 wasn't obd2 compliant, you may need a vcm1 as they are more successful than clone vcm2
07 350 170ps
Ids map here
loot
Postby spudmab » Tue Jun 30, 2020 7:29 pm
Its a 53plate so i guess vcm2 will not be the best,
any ideas where i can get a vcm1 from,
i wanna see if my truck has a speed limiter set, i can read codes ect with forscan done injectors with that as well but the idea of ids and vcm to allow key programming and other stuff was why i brought it.
spudmab
Postby karl » Tue Jun 30, 2020 10:46 pm
were is the best place to buy ids now
i lost all my diagnostics gear when a company were i left it got flooded computer the lot tried drying it all out but its all dead :( :(
need to get me ids going asap
i have got ford scan but carnt seem to get it working at all
not good at loading software and getting it working
karl
Tranny Lover!!!
Postby loot » Wed Jul 01, 2020 10:07 am
No idea, didn't you have ids3 Karl?
07 350 170ps
Ids map here
loot
Postby karl » Thu Jul 02, 2020 10:07 pm
loot wrote:No idea, didn't you have ids3 Karl?
updated it but locked me out just trying to sort it as am writing this :(
should never of updated it lol
am downloading your v86 then go from their
got v86 running and believe it or not me vcm is working as well after it was under 4ft of water :lol: :lol:
karl
Tranny Lover!!!
