DougT wrote:Can't really tell from any photos as the critical issue is the bore diameter. So you need to get one out and measure the bore diameter as accurately as you can.
I use a company called "brakeparts.co.uk" who list the parts even if they do not have them. So it is a good source of reference to find out what the options are. For a 77 Mk1 they list the rear cylinders as 19mm bore but trawling around there are earlier versions at 20.3mm and 16mm. Their photos are pretty good and generally are of the part rather than a similar item. Be a bit careful as the tendancy in those days was to fit what was on the shelf even if it wasn't the specified part !! And as they were starting to change to the Mk2 I would check the options from the early Mk2 list as well.
Doug
