Pictures of all available correct size pcd Transit alloys
Re: Pictures of all available correct size pcd Transit alloy
Postby wojciech » Wed Feb 05, 2020 8:46 pm
OEM Transit Mk4 alloys, size 5,5"Jx14"
wojciech
Postby wojciech » Tue Jun 02, 2020 7:45 pm
1AV, model ZX11T, size 8Jx18", PCD 5x160mm, ET 50mm, load rating 1.000kg, finishing Glossy Grey.
wojciech
Postby wojciech » Sun Jul 19, 2020 7:23 pm
GMP Italia, model JOB, size 6,6Jx16", PCD 5x 160 mm, CB 65,1mm, ET 48 mm, finishing SI silver gloss
wojciech
Postby wojciech » Sun Jul 19, 2020 7:38 pm
BORBET model CWF, , size 6,6Jx16", PCD 5x 160 mm, CB 65,1mm, ET 60 mm, finishing BG black glossy SG silver glossy, TÜV certificate
Wheels identical to GMP Italia, model JOB, only ET differ
wojciech
Postby wojciech » Sun Aug 02, 2020 9:05 am
CWS USA (Custom Wheel Solution), model: RV Wheels Transit 350HD, alloys for DRW models, diameter 16", front offset -121, rear offset - 143, finishing: PVD Finish or Machine Finish
Supplied with 24 nuts, factory nuts cannot be used. In the photo, the double tires are size 215/85 / R16.
Pictures are from https://www.fordtransitusaforum.com/thr ... 266/page-2
https://www.cwswheels.com/wheels/rv-wheels/
wojciech
Postby wojciech » Sun Aug 02, 2020 9:57 am
Ultra, model 003BM Hunter Van Dually, size 6jx16", finishing: Gloss Black with Milled Accents (nr. 4576) or Chrome Plated (nr. 4577).
003 Hunter are also produced in size 6.5Jx17 " (respectively nr. 4333 and 4334)
Free chrome lug kit included with the purchase of a set of 4 Ultra 003BM
https://www.customwheelsexpress.com/ultra-c-21_34.html
wojciech
Postby wojciech » Mon Aug 10, 2020 10:30 pm
OZ Racing , model Rally Racing Van, size 75Jx18", PCD 5 x 160 mm, ET 48 mm, finishing: White, Graphite or Black
wojciech
Postby wojciech » Tue Aug 11, 2020 9:29 am
BLACK RHINO, model ARSENAL, size 8.0Jx16", PCD 5x160mm, ET 38 mm, load rating: 2700 lbs (1.225 kg), finishing: MATT BLACK or SAND on BLACK
wojciech
Postby wojciech » Tue Aug 11, 2020 9:48 am
BLACK RHINO , model HAVASU, size 7.5Jx17" ET 45mm and 8.0Jx18" ET 48mm, PCD 5 x 160 mm, load rating 1.350 kg, finishing: MATT BLACK
wojciech
Postby wojciech » Tue Aug 11, 2020 2:15 pm
wojciech wrote:OZ Racing , model Rally Racing Van, size 7.5Jx18", PCD 5 x 160 mm, ET 48 mm, finishing: White, Graphite or Black
wojciech
Postby wojciech » Thu Sep 10, 2020 8:40 pm
Inter Action Wheels, model KARGIN, size 6.5Jx16", PCD 5 x 160 mm, CB 72,6 mm (set of intermediate rings included), ET 50 mm,load 1.000 kg (2.200 lbs), finishing: silver gloss, black matt and gloss black polished
Certificate: VIA, JWL
wojciech
Postby wojciech » Thu Sep 10, 2020 9:53 pm
OXXO Alloy Wheels, model HYPERION, size: 6.5Jx16", ET 60mm and 7.0Jx17", PCD 5 x 160 mm, ET 55mm, load 1,200 kg (2,650 lbs), finishing: Silver and Black.
Certificate: TUV.
Approval: German KBA and European ECE R-124.
wojciech
Postby wojciech » Mon Dec 28, 2020 10:57 pm
Black Rhino, model OVERLAND. size 8Jx18", PCD 5x160mm, ET 48mm, CB 65,1mm, finishing: Black Matt
wojciech
Postby captinbob » Tue Oct 05, 2021 6:31 pm
what happened to all the pre 2019 posts or did i just imagine that?
captinbob
Postby Altransit » Tue Oct 05, 2021 7:33 pm
captinbob wrote:what happened to all the pre 2019 posts or did i just imagine that?
Photobucket very kindly deleted all of the image links, so wojciech painstakingly reposted them all.
