Chuggy wrote:If it pumps up and pedal goes hard then it probably just needs shoes adjusting
Neil wrote:have you changed all the flexis ?
Chuggy wrote:If it pumps up and pedal goes hard then it probably just needs shoes adjusting, or you've got air in the system somewhere...master cylinder seals?
Neil wrote:get the servo reconditioned
conrod wrote:Do your front brake calipers have multiple bleed screws? (the 4 pot calipers can have 3 bleed screws per side) Did you bleed from all of them? Borrow a vacuum bleeder and try it with that.
Mk1-nightmare wrote:Neil wrote:get the servo reconditioned
Hello Neil. I have sent it away to be reconditioned
