horn beeps twice when i put central locking on
Postby rob4155 » Sun Oct 04, 2020 8:42 am
Hi i have a 2016 ford transit custom,every time i put central locking on the horn beeps twice,it has only started doing this recently,has anybody an idea why it has started doing this,thanks
rob4155
Re: horn beeps twice when i put central locking on
Postby blue estate » Sun Oct 04, 2020 8:48 am
Faulty door lock , so eco thinks door is still open
Sent from some where
blue estate
Postby knobby1 » Sun Oct 04, 2020 9:03 am
BCM "thinks" a door is open...you must have a faulty doorlock mechanism.
Postby johnenigma » Sun Oct 04, 2020 10:19 am
If you can't find anything obvious, try looking at the centre roller on the SLD. There should be a rubber tyre on the roller, that comes off or goes missing. This allows the door to drop slightly so missing the contacts. There should be an even gap around the door about the size of a £1 coin.
Sent from my SM-G955F using Tapatalk
johnenigma
Postby rob4155 » Sun Oct 04, 2020 11:57 am
if one of the door locks is faulty is there a way of finding which door lock it is ?
rob4155
Postby johnenigma » Sun Oct 04, 2020 1:07 pm
rob4155 wrote:if one of the door locks is faulty is there a way of finding which door lock it is ?
Try locking or unlocking, then go round the van and see which individual door is either locked or unlocked in relation to the other doors.
johnenigma
Postby andz327 » Sun Oct 04, 2020 9:37 pm
Clean the contact pads and pins for sliding door
ANDZ
andz327
Postby Back.bone.brit » Sun Oct 18, 2020 7:15 pm
Hi new here hoping some one can help got a 2018 transit custom that says door opened.
When lock get the 2 beeps. Front doors lock just side door and rear. Is there any way of testing the rear locks?
Back.bone.brit
Postby Rodduz » Thu May 09, 2024 10:07 pm
Sorry resurrect a thread but thought better than making a new one.
Got the two beeps happening on mine, only bought it today. Crew cab sliding door isn't locking at all when use fob or key in drivers door lock.
2019 plate.
It'll be going back garage for them to sort but in the mean time how can I manually lock the rear sliding door as currently anyone can get in and I presume unlock all other doors with the button in the front?
Sent from my SM-S911B using Tapatalk
Rodduz
Postby Bezwest78 » Sun May 12, 2024 6:59 pm
I’ve started having the similar problem. My transit custom 2017 is intermittently double beeping when locking but when checking doors they are all locked. When unlocking and opening and shutting individually doors it sometimes stops it but doesn’t seem to be a certain door. Not sure what to try
Bezwest78
