1995 Hallmark Rustoration
Re: 1995 Hallmark Rustoration
Postby MinorMatt » Tue Sep 29, 2020 10:55 pm
Just for future reference...
Additional options:
With Straight Rear Exhaust Exit
With Standard Tyre Tread - Rear
Front Axle Rating-Normal
With Standard Tyre Tread - Front
I/P Pull Out Cup Holder
I/P Rubbermat
Rear Axle Less Limited Slip Diff
With High Centre Of Gravity Pack
With Insulator
With Engine Compartment Noise Pack
With Plastic Fuel Tank
With Handbrake Boot
With Smoke Compliance Label
With Rear Tow Hooks
With Engine Dash Insulator
With Front Mudflaps
With Rear Mudflaps
With Load Space Tie Down Loop
Standard Duty Battery
Any Brand Tyre Vendor
With Heated Windscreen
With Load Compartment Lamp
With Radio Pre-Equipment Pack 1
With Cigar Lighter
With Door Map Pocket
With Tool Kit
With Laminated Windscreen
Manual Slam Rear Door Lock
With 3 Point Seat Belts
With Noise Insulation Pack
With Moulded Board Trim
With 180° Cargo Door Check Arms
With Front Roof Grab Handle
With Exterior Tyre Carrier
With Fixed Rear Window
With Front 2 Way Headrest
With Power Front Windows
With Timkin Axle
With Analogue Clock
With Wide Body Moulding
LH Sliding Side Cargo Door - Low
With Fixed Front Passenger Seat
With Partial Headlining - Moulded
With Sunvisor Mirror - Passenger
With Vertical Split Braking System
With Clear Glass - Complete
With Luxury Wheel Cover
With Steel Spare Wheel
With Power Steering(Fixed Ratio)
With bosch Fuel Injection Equipment
With Sngle.L/B Dvr/Dual L/B Pass.St
With 3563 LB(1620 Kg)Rear Axle Assy
Less Air Conditioning
With Standard Suspension
RHD RWD
Rear Bumper Body Coloured Plastic
Passenger Short Arm Power Mirror
Southampton Plant Built
Front Bumper Body Coloured Plastic
95 EEC Light Duty Truck
4.56
195R x 14C BSW-6PR Tyres
100S
Regular Cargo Van
5-Speed Manual Transmission - MT75
(+)"GB"
Medium Opal Grey
2.5L Diesel (76PS)
Transit 1995-2000
Diamond White 73
G-C Camelot
Postby MinorMatt » Mon Oct 05, 2020 11:17 am
I took a few pictures at the weekend, and will upload them later.
I found a slightly shonkey 063 battery in the workshop too, so I put it on, realised the battery clamps weren't great so clamped it on with m ole grips and....
Click click click whuuuuuurrr
So got the jump start on it too, and half a turn later it was up and running happily. I will have to get it off the trailer and see if the brakes work next :lol:
Postby Adam mk1 » Mon Oct 05, 2020 4:37 pm
High centre of gravity pack? I thought it would be sitting up at the back, or does it mean something else, good that it has 4.56 diff, ive just bought one from a breakers yard, diff not the hole van
Adam mk1
Location: Live in southsea Portsmouth, work nr Winchester
Postby ned » Mon Oct 05, 2020 6:15 pm
Is the driver's side mirror not powered?
So they were made in 3 colours, white, silver and ?
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Keef » Mon Oct 05, 2020 6:36 pm
ned wrote:So they were made in 3 colours, white, silver and ?
MinorMatt wrote:Ford made 200 in white, 200 in silver and 200 in blue.
Keef
Postby ned » Mon Oct 05, 2020 6:40 pm
:oops: didn't see that bit on the original post, my bad, I must be punished
ned
Postby Keef » Mon Oct 05, 2020 7:00 pm
Wouldn't worry, until there's photos posted, the van's a figment of Matt's imagination anyway!
Keef
Postby Chug » Mon Oct 05, 2020 10:04 pm
How much did you shell out for your rust pile Matt?
Chug
Postby MinorMatt » Tue Oct 06, 2020 8:30 am
Keef wrote:Wouldn't worry, until there's photos posted, the van's a figment of Matt's imagination anyway!
There is a picture on the previous page :lol: but yes I have more to add. The perils of having IT access but no phone at work :lol:
Chug wrote:How much did you shell out for your rust pile Matt?
Lets put it this way, I could break it and make good money... and surprisingly its not *that* rusty. I have done far far worse!
Postby MinorMatt » Tue Oct 06, 2020 12:03 pm
Pics!
Postby MinorMatt » Tue Oct 06, 2020 12:04 pm
another
Postby MinorMatt » Tue Oct 06, 2020 12:05 pm
and again
again...
Postby MinorMatt » Tue Oct 06, 2020 12:06 pm
more
Postby MinorMatt » Tue Oct 06, 2020 12:07 pm
