What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby madtheswine99 » Sat Oct 17, 2020 9:45 pm
bros400pgmFORD wrote:Fitted an android radio/gps/etc player Image
Is that a LHD, as my 12v socket is the other side of my gear lever and the little flap pocket is as well.
madtheswine99
Postby bros400pgm » Sun Oct 18, 2020 6:11 am
Looks smart
Could almost be factory fitted.
Sent from my SM-A107F using Tapatalk
It's exactly the same in dimensions as the 1500. Plug n play installation ;)
bros400pgm
Postby bros400pgm » Sun Oct 18, 2020 6:12 am
Yeap. Left hand drive :)
bros400pgm
Postby Scooby doo » Mon Oct 19, 2020 6:29 pm
spoonman wrote:
Scooby doo wrote:Just the sides...one on each, as far as I’m aware they are screwed to the outer a pillar trim, tho I can get some pics for you tomorrow if need em..
I appreciate if you take some pics. :wink:
Cheers,
Lars
Sorry it’s late replying, my minds been all over the place, but it’s mounted the same both sides..
Scooby doo
Postby Greg71 » Mon Oct 19, 2020 6:31 pm
Had to smash off my air intake manifold today, every bolt had rounded off so it was the only way.
Replaced the manifold, intercooler, hoses and other bits.
Took a while but needed doing, it was well caked up and the intercooler had more oil in than the engine!
Greg71
Postby Greg71 » Mon Oct 19, 2020 6:40 pm
The dirty job.
Greg71
Postby RustWidow » Mon Oct 19, 2020 9:18 pm
Greg71 wrote:The dirty job.
Looks like you had fun there
RustWidow
Postby spoonman » Wed Oct 21, 2020 4:33 pm
Cheers,
Lars
Thanks a lot :)
Cheers,
Lars
spoonman
Postby dirtydog » Thu Oct 22, 2020 10:23 pm
Had to replace an injector clamp and bolt yesterday after it came loose and the injectors were bouncing around, van has cost me a few hundred quid in the past few weeks with front wheel bearings, brakes, drop links, arb bushes and then the injector clamp yesterday.
dirtydog
Postby walt1984 » Fri Oct 23, 2020 4:38 pm
At least it should be reyt now.
Still havnt done my wheel bearing.
Got new breaker bar, 36mm socket and the amazon t50 you reccomended but it keeps raining.
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
Postby DG-Unit » Fri Oct 23, 2020 4:54 pm
walt1984 wrote:Still havnt done my wheel bearing.
What are you planning to use to get the old one off and new one on?
2004 Transit SWB 85 T260
DG-Unit
Postby walt1984 » Fri Oct 23, 2020 5:06 pm
Ah now I have a plan lol.
I dont want be stuck with van in bits so I bought a new cheap hub and bearing and got a mate to press them together.
I'll keep the original and get him to swap bearing for a decent one ready for when passenger side or cheap bearing throws towel in.
Or when funds permit I'll get a decent bearing puller.
walt1984
Postby Leo45 » Fri Oct 23, 2020 6:08 pm
Fitted a Parrot handsfree unit, found out that the wire color black (universaly consisdered as ground) is not a ground when fitted in a transit.
Yellow most times used a contact plus is ground. But red is plus 12V!! Hurrah.
While havind troubles with a radio wiring I found a display of my PDC tucked away. Why the previous owner did that I don't know it seems to work OK..
Anyway a day well spent..
Leo
My first Ford ever, a dual sliding door 2010 Mk7. Now I'm a true "white van man."
Leo45
Postby dirtydog » Fri Oct 23, 2020 11:23 pm
walt1984 wrote:At least it should be reyt now.
You'd think it would be fine now, engine light came on again :roll:
Not plugged it in yet though
dirtydog
Postby loot » Thu Oct 29, 2020 11:34 pm
Took it for mot and it failed on guess...
Rust.
Inner and outer sills
Track rod end.
Both front, rear wishbone bushes.
Handbrake low.
Emissions.
Headlamp aim low.
But worried about the emissions. I was able to reset my prv counter. When I got the van I put mine in that we're questionable but it passed both learns. I think the flow plugs are shot and it smokes under load, there's also a big gulp of loss of boost which could be why. I need to check for boost leaks. Could end up needing new valves and injectors, or turbo actuator. :(
07 350 170ps
Ids map here
loot
Users browsing this forum: wardus212
