Breaking mk4 LWB HI TOP 100ps 190
Re: Breaking mk4 LWB HI TOP 100ps 190
Postby Adam mk1 » Tue Nov 03, 2020 11:57 pm
Chris21r wrote:Hello
Are Both door cards still available?
And the rubber floor mat, inc strut top covers still available?
Best text me people are asking about bits these bits might be sold soon so contact me
Adam mk1
Location: Live in southsea Portsmouth, work nr Winchester
Postby hetman » Sat Nov 21, 2020 8:37 am
This van has a 5-speed manual transmission, correct? Do you have the plug that goes into the backup light switch in the transmission housing? Plus 6+ inches of wiring so I can splice it in to my wiring harness? I'd be very grateful. Thank you.
I'm located in Poland.
Is the latch/locking mechanism on the hood (bonnet) working correctly? If so, I'd like to as for that as well. Mine is missing some parts.
Another item I'd greatly desire would be the rod that actuates the spare tire lift system, but the backup light plug is very important.
Mike
hetman
Postby Adam mk1 » Sat Nov 21, 2020 5:21 pm
Hello hetman, the van has epic pump and so needs wiring complete for engine & gearbox to work correctly i may need to fit in another vehicle, not sure my van has spare wheel tool, and also bonnet does not lock, could be lack of oil, next time im there will be Monday i will look for you, Adam
Adam mk1
Postby hetman » Sat Nov 21, 2020 10:28 pm
OK, thanks for the info, Adam. I'll try to fix my problem somehow.
Mike
hetman
Postby Adam mk1 » Thu Dec 03, 2020 5:09 pm
Adam mk1
Postby Adam mk1 » Thu Dec 03, 2020 5:10 pm
Adam mk1
Postby Adam mk1 » Thu Dec 03, 2020 5:11 pm
Adam mk1
Postby Adam mk1 » Thu Dec 03, 2020 5:12 pm
Adam mk1
Postby Adam mk1 » Thu Dec 03, 2020 5:15 pm
Water tank is 28in, 19in,10in
Both front seats are identical
Adam mk1
Postby Adam mk1 » Thu Dec 03, 2020 5:16 pm
Adam mk1
Postby Adam mk1 » Thu Dec 03, 2020 5:17 pm
Water pump untested
Adam mk1
Postby transit-richard » Fri Jan 01, 2021 1:17 pm
Hello,
Do you have this strut available please?
transit-richard
Postby Adam mk1 » Wed Mar 10, 2021 2:59 am
I'm going to chop this up this week & next week then what ever I can't be bothered to remove will go in the crusher
Adam mk1
Postby Keef » Wed Mar 10, 2021 12:25 pm
I thought you'd decided to sell it whole?
viewtopic.php?f=7&t=204411&p=1714923#p1714923
You didn't get back to me about the parts I wanted.
Keef
Postby MinorMatt » Wed Mar 10, 2021 12:32 pm
If someone else isn't already in line, and you don't want it - take the grille off for me please Adam!
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
