oil leak caused by carter ventilation?
Postby tomvdrunen » Wed Nov 25, 2020 3:39 pm
i have a ford transit MK1 2400 Diesel with a big oil leak.
i noticed that the oil comes outside of the oil dipstick (when the engine is running (when you are driving)
so there is overpressure in the carter?
can this be the carter ventilation?
where and how is this mounted? what could i clean?
the engine have engough power (driving is oke) and there is no coolant loose.
(so it's not the cylinderhead or piston rings i suppose.
tomvdrunen
Return to Mk 1 & 2
