by spangled949 » Thu Nov 26, 2020 3:59 pm
I'm selling a Mk7 transit that is just out of mot and no longer needed.I've had the van since March and when got it the handbrake cable was snapped and still is.Currently can't get into it as been sat for a couple of mths outside flat.reg numbers mf58lxx if you want to check mot history.Will be as honest as can about what it needs but no mechanic.Right when last drove her over to a friends a couple of times she wouldn't come out of gear and prior to that the clutch had started to slip.Its has a touchscreen head unit though needs an update for the sat nav.Side and rear door has security locks and I'm sure it wouldn't take too much time to get through an mot.The reason i bought it was that when checked mot history it never had any advisories for rust.when bought was told had a replacement engine though no paperwork to prove but she does get up and go and is very nippy indeed.Will add some pics as soon as get chance but just want rid of it now.Not sure what shes worth but too good to break.Will need to be trailered and because cant use hand brake it was left in gear.Any offers considered but as said would is not drive able at moment.
