Hot water
Hot water
Postby Itlldo989 » Mon Nov 16, 2020 5:32 pm
Does anyone on here have an ex welfare van and know how to get hot water working please. I have an ebachcter heating/water system?
Itlldo989
Re: Hot water
Postby Jetto » Sun Nov 22, 2020 8:21 pm
Not sure what you're asking really. The eberspacher heats an exchanger that your water runs through. Some are built with thermostatic valves to control the max temp.
Jetto
Re: Hot water
Postby Itlldo989 » Thu Nov 26, 2020 6:23 pm
Basically the heating work's fine but the water has never heated up?
Itlldo989
Re: Hot water
Postby Jetto » Sun Nov 29, 2020 4:37 pm
Could be a lot of things. One, it's not hooked up, two, it's on a solenoid switch that needs to be turned on. If it's never worked and it's not your install, I'd lean towards #1. Follow the lines and look for a heat exchanger that your hot water line runs in to.
Jetto
Re: Hot water
Postby Itlldo989 » Sat Nov 27, 2021 8:08 pm
I now have my hot water working but am unsure what oil goes in the plastic tub near the sink above the boiler ? Is this waste .
Itlldo989
