part required for my mk1
Postby shepped0 » Fri Dec 18, 2020 2:50 pm
Hi All
Hoping for some help.
My mk1 panel van is in need of a part which i am struggling to find.
On the hand brake there is a cable that is attached to a rod (which goes through chassis) then attached to another cable and via a horseshoe mechanism pulls both rear brakes . The cable is the part i am after as it has seize and can be properly activated. Any help greatly appreciated
shepped0
Re: part required for my mk1
Postby shepped0 » Fri Dec 18, 2020 3:08 pm
excuse my ignorance but it could be called a Pagid Brake cable ??
shepped0
Postby DougT » Fri Dec 18, 2020 6:16 pm
Is it a SWB or LWB van ?
The parts manual just calls it the parking brake cable. There are 2 versions of different lengths depending on SWB or LWB. So best to remove it and measure as actually there have been instances of the wrong cable being fitted and the rod length adjusted to fit.
There are cables of each length listed on ebay.
Pagid is just a manufacturer of brake components so may have produced them in the past but I suspect would no longer do so.
Doug
DougT
Postby shepped0 » Fri Dec 18, 2020 9:42 pm
Hi Doug
Thanks for your reply
My van is definatly a short wheel base but i take your point.
Do you have any part numbers ?
thank you
shepped0
Postby shepped0 » Fri Dec 18, 2020 9:43 pm
or a link
shepped0
Postby DougT » Fri Dec 18, 2020 10:48 pm
These are the Ford part numbers for the Mk1
SWB - Finis 1503957 Part number 69VB 2A604 AA
LWB - Finis 1503958 Part Number 69VB 2A604 BA
What I was looking at on ebay were in fact Mk2 handbrake cables and having double checked, it appears that they are different lengths from the Mk1 versions. Sorry about that. But if you search Mk2 Handbrake cables on ebay then they will come up.
The correct ones are available but pricey from Motomobil in Germany. But I would be seriously tempted to measure up the existing one and then look at the Mk2 cables to see if they would work with particular attention to the end fittings. And it looks like the SWB cable is longer than the LWB one which seems backwards but there will be Ford logic somewhere in that arrangement.
Doug
DougT
Postby Luke » Fri Dec 18, 2020 11:17 pm
could you not get a mk3 one to fit?
Postby shepped0 » Sat Dec 19, 2020 2:13 am
Thanks Guys...Ford dont make it simple do they
It is in with a garage at the moment i havent got the time to play around with it...so i will try and get them to measure up first. Failing that i may get it home and over the Christmas break have a look myself especially if you think the ends may be different which will cause a big problem
You say the ones on Ebay are mk2's but not likely to fit......I was going to go on your part numbers only but are you saying the mk2 have a chance of fitting?
I have spoken with a couple of guys who specialize in type of things and even for them its not clear cut
shepped0
Postby Ralph.9 » Sat Dec 19, 2020 8:09 am
It shouldn't be a cable but an adjustable rod from the pivot at the bottom of the lever to the horse shoe, the only ones that used a short cable were very early German vans. I should have a good used rod as im dismantling a MK1 at the moment.
Ralph.9
Postby DougT » Sat Dec 19, 2020 10:11 am
Unfortunately it is just one of those things that unless someone tries then it is difficult to tell whether the Mk2 cable will work. Personally I would guess that it would and with the cost difference, for myself I would give it a try. But there might be a problem.
These diagrams are taken from the Mk2 Ford workshop manual in case it helps to compare the systems.
Luke, an interesting comment on the Mk3. Have you made any comparisons yourself ?
Doug
DougT
Postby Luke » Sat Dec 19, 2020 1:53 pm
DougT wrote:Luke, an interesting comment on the Mk3. Have you made any comparisons yourself ?
no but they are very similar i would be surprised if they couldn't be adapted
Postby shepped0 » Sat Dec 19, 2020 10:56 pm
Hi Guys thank you for all your input could this item be worth a punt?
ttps://www.ebay.co.uk/itm/Cable-Freno-M ... t4AAOSwDgt
It is abroad but has the same part number for a mark one SWB
shepped0
Postby shepped0 » Sat Dec 19, 2020 10:58 pm
shepped0
Postby Ralph.9 » Sun Dec 20, 2020 9:24 am
Thats a LWB 100L cable.
Ralph.9
Postby Neil » Sun Dec 20, 2020 10:23 am
try a classic brake specialist they may have one in stock
Neil v6
Neil
Return to Mk 1 & 2
