Mk7 cranking won’t start
Postby Jay572 » Sat Feb 13, 2021 10:19 pm
Evening all
I’m brand new to this but have driven transits most of my life!! I have a mk7 transit trend model 2010 with 144k.
Pretty much a year ago to the day I went to start it and all it did was turn over and over, tried it later that day and the next day same thing just turning over. Tried it about 3 days later and it started on the button as tho nothing had happened, that weekend it did the same thing in total I think it did it 3 times over the course of about 3 weeks. Never did it again until today. Back to yesterday minus 4 out and it started on the button drove it about all day no problems, went to start it this morning and it’s just turning over and over without starting, same thing as a year ago..... weird strange and I’m lost to as what to do.... I have had the crank sensor changed, all glow plugs replaced with genuine, correct oil and oil and fuel filter changed
EGR cleaned, all in the last year but not recently.... if anyone could help please...... thanks
Jay572
Re: Mk7 cranking won’t start
Postby Stumble » Sat Feb 13, 2021 11:55 pm
Could be your ignition switch, needs renewing
Stumble
Postby Jay572 » Sat Feb 13, 2021 11:59 pm
Ok thanks, would that let the engine crank over?? Or would there be nothing?.
Jay572
Postby Stumble » Sun Feb 14, 2021 12:21 am
Apparently your symptoms are classic for ignition switch playing up, there are others
luckily they're inexpensive and if yours hasn't been done, probably best to eliminate it as a cause
IMHO,
Stumble
Stumble
Postby andz327 » Sun Feb 14, 2021 6:16 am
As Stumble said put switch on it, RATES FORD DEALER is on ebay and your better wirh genuine switch , it's a boot £20 inc postage and usually get next day if you buy it early enough to catch their post.....
It could be a sign that timing chain or tensioner or both on way out but get your switch on first ,
Same again if you ever need to put chain on it get GENUINE parts
ANDZ
andz327
Postby Jay572 » Sun Feb 14, 2021 10:10 am
Ok great I’ll order one today.. is RATES FORD DEALER the name of the seller
Jay572
Postby Stumble » Sun Feb 14, 2021 10:30 am
https://www.ebay.co.uk/itm/272377706457&seller=&toolid=10018&91974839" rel="nofollow">https://www.ebay.co.uk/itm/Genuine-Ford ... 2377706457
Stumble
Postby Jay572 » Sun Feb 14, 2021 10:39 am
hi
sorry i cant seem to get that link to open... frustrating!!
thanks
Jay572
Postby v8dave » Sun Feb 14, 2021 12:36 pm
Search ebay for https://www.ebay.co.uk/itm/272377706457 which is th elisting number
or 1677531 which is the ford part number for the ignition switch
v8dave
Postby v8dave » Sun Feb 14, 2021 12:39 pm
Search ebay for
Code: Select all
The forum hijacks ebay listings and. if you don't allow cookies from anybody, breaks the link.
Even when I use a code block to isolate the number it still get hijacked.
Bl88dy stupid software !!
v8dave
Postby Stumble » Sun Feb 14, 2021 12:54 pm
Copy and paste this item number into e Bay search bar =
Code: Select all
Couldn't agree more
Stumble
Postby Jay572 » Sun Feb 14, 2021 2:00 pm
Thanks every one managed to find it and on order.. I will update when it arrives
Jay572
Postby Jay572 » Sun Feb 14, 2021 2:30 pm
I have out this morning, sounds slot better like it’s trying to start.. tried to attach a video but it won’t let me..
Will keep trying.. thanks
Jay572
Postby Jay572 » Sun Feb 14, 2021 2:48 pm
Been out again and the white/see through pipe from the fuel filter to the fuel pump has air pockets in. When I turn it over I can’t see the fuel/air pockets moving. It now turns over goes to fire but doesn’t..
Jay572
