Mike wrote:I didn’t send you anything to do with a Custom, I think you’re the one who’s confused. Unless you’d like to point out where I sent you a link for the Custom?
I rest my case.
Flatfish wrote:Mike wrote:I didn’t send you anything to do with a Custom, I think you’re the one who’s confused. Unless you’d like to point out where I sent you a link for the Custom?
I rest my case.
APW wrote:FlatFish…. Mike is correct, he helpfully posted a link for the BEMM PDF for a Mk8 transit because you asked in the Mk8 transit forum:
viewtopic.php?f=64&t=205379&p=1721025#p1721025
If you had asked in the Transit Custom forum, I have no doubt that he would have posted a link for the BEMM pdf for a custom….
BTW, I have no idea why I’m getting involved here, Mike is a big boy and is more than capable of standing up for himself!!
Mike wrote:It’s obvious from very early on that fatfish’s posts are ambiguous, there could be a number if reasons for this, I’ve seen it in the past where people do it so they can cause an argument later, but still claim the moral high ground, or it could just be that he’s a bit simple, make up your own minds.
The ambiguity in his posts meant that I opted to give him the benefit of doubt when he asked about his load liner. He posted in the MK8 section, rather than question him (he doesn’t take well to that) I chose to supply exactly the info that he’d asked for. For which he thanked me.
A day or so later I was advised that, 1:Custom load liners aren’t glued down, and 2:He’d probably mistakenly posted in the wrong section. I chose not to get more involved in his post because, well he’s a bit of a twat.
He then stupidly chose to attack me again in a thread that had nothing to do with him, other than he chose to post poor advice in it.
So Mr Fatfish, I suggest that you concentrate on posting more accurately, I’m sure one of my ‘girlfriends’ could help.
Flatfish wrote:
You need to find a mirror this evening little mike, have a real good look.
mikeoats wrote:I have been lurking on this forum since I bought my custom just over a year ago, this forum is full of great advice and problem finding/solutions, but I have noticed that its also toxic af at times and its usually the same two names that are responsible so please for the sake of all the non keyboard warriors who just want some info or advice please just keep your bullshit to yourselves.
That’s all very well, BUT. It’s a regular question here, my van sits down when I put a load in it. Ok, so what’s the solution? The solution isn’t to put uprated springs on it! There are a few solutions, firstly and easiest, stop overloading it. If you bought a 290 and needed a 330, then don’t blame Ford. Secondly, if it’s broken, have it fixed with the correct springs, not uprated ones that could affect the safety of your van.
So, when someone comes and asks a daft question that gets asked once a month, no I won’t ignore it and I certainly won’t be subtle in my reply. And then when some daft c*** called fatfish comes along with obviously dangerous suggestions, I won’t hold back either, especially as he won’t even take responsibility for his own actions! Hell, he doesn’t even know the difference between a Custom and a MK8, and he’s had one new van for a few months (and broken it already) and he thinks I have an issue with shiny new vans, which just highlights his ignorance.
So I’m sorry if it upsets you mikeoats, but as the only contribution you’ve made here is to have a moan…
As for you V184, wind your neck in, you’re just sticking your oar in because you get your wings clipped for posting shite
Mike
Wind up merchant!
mikeoats wrote:If it bugs you that much that you have to turn to petty insults then maybe your should rethink about wasting your time reading them……..maybe if I draw a doll you can show us where he touched you ?
mikeoats wrote:That’s all very well, BUT. It’s a regular question here, my van sits down when I put a load in it. Ok, so what’s the solution? The solution isn’t to put uprated springs on it! There are a few solutions, firstly and easiest, stop overloading it. If you bought a 290 and needed a 330, then don’t blame Ford. Secondly, if it’s broken, have it fixed with the correct springs, not uprated ones that could affect the safety of your van.
Mike
Wind up merchant!
Unless this is your forum people can ask what ever questions they want ?
If it bugs you that much that you have to turn to petty insults then maybe your should rethink about wasting your time reading them, this is certainly not the first thread I have read with you gobbing off to flatfish either maybe if I draw a doll you can show us where he touched you ?
Flatfish wrote: He and his girlfriends made a pact to ignore me.
